Barrel
Hoonigan
Have you done 1/2 mile before? You have a lot of open area in the grill for 200+.Ill be shooting for 200 this fall in Dallas.
Lost my stock motor with the Whipple at one.Have you done 1/2 mile before? You have a lot of open area in the grill for 200+.
I think I was there for that one in Dallas when it broke 200. It was not easy and they were making every bit of 1300rwhp. Made a couple 190+ passes before they got there. Biggest trouble (and what we all struggle with) is traction on launch. They kept messing with boost ramp to get it off the line - pretty much leaving on idle.I think LPF has the only coyote ( relatively streetable one anyways) running 200 in the half. Be cool if you could beat it!
Power should be there. We maxed out the dyno at 180mph. 1250@6k on 26psi. Going to up to 30. But I am worried about aerodynamics and traction. I only had three goals on this build, streetable, 8 second quarter and 200 in the half. I guess time will tell. LolI think I was there for that one in Dallas when it broke 200. It was not easy and they were making every bit of 1300rwhp. Made a couple 190+ passes before they got there. Biggest trouble (and what we all struggle with) is traction on launch. They kept messing with boost ramp to get it off the line - pretty much leaving on idle.
Hood pins lol. I have a video floating around on here showing the stock hood raising a couple inches. lolWhat are some simple aerodynamic items are you considering? I'm doing the Texas Mile next month for the first time and I've really only added Trackspec hood vents. Would be nice to get some tips and tricks on our cars before I attempt it.
A CF hood and aero latches has made a huge difference for me. The stock hood would wave at me at 60mph. The new setup is WAY MORE STABLE!Hood pins lol. I have a video floating around on here showing the stock hood raising a couple inches. lol
i think you will. I did 165 with about 720-740rwhp. I think atleast 800 would be needed for 170 but I could be wrong. weather probably affects this a lot too
I'm hoping to crack 170 with 750 on premium pump gas. Ocala's elevation and the weather will be the ideal place. In all the half miles I've done, stock 15-17 S550s have trapped low-mid 130s and I ran 143.2 stock. The A10 and better aero on the 18+ definitely helps. Guess we'll see.Yeah you need 800 or more for 170.
If you guys are at Ocala, stop and say hi. I'm bringing one of the Ford engineers with me from work and we always like to talk with Ford fans.
I'm pretty sure I'll be there - look out for the bright yellow '15!I'm hoping to crack 170 with 750 on premium pump gas. Ocala's elevation and the weather will be the ideal place. In all the half miles I've done, stock 15-17 S550s have trapped low-mid 130s and I ran 143.2 stock. The A10 and better aero on the 18+ definitely helps. Guess we'll see.
