Hot Rod Magazine Review (GT & EcoBoost)
Fenderaddict2
Oakville
www.fastmyles.com
Stephen
2012 Mustang Boss 302
http://www.hotrod.com/muscle_car_re...ustang_ecoboost_and_5_liter_v8/?__federated=1
As we’re sure you can imagine the new 2015 Mustang is beyond anything ever available in this price range in terms of looks, performance, handling and build quality—but you knew that already. We got a chance to flog both a 2.3-liter EcoBoost banger, and the new 5-liter V8 through the hills and twisties around Malibu, California. There is also a V6 option but the small buy in for the EcoBoost makes the V6 a non-starter. Both of our Mustangs were hooked to the 6-speed manual trans with Hill Start Assist. We’ll give you the quick rundown on the handling, but then we’ll fill you in on what the Mustang Manager and lead engine engineer told us about some of the unspoken features you’ll want to know about.
With a tighter cabin and more horsepower than the previous Mustang, we found it remained neutral throughout each turn. No hop, skip and jump over uneven pavement as in previous Mustangs. Three suspension settings are available; Sport, Sport+, and Track, at the flip of a toggle, and there was a noticeable difference with each successive mode. Sport was the mild mannered setting, which we found most comfortable on the crappy asphalt roads on and around Mulholland Drive. But for cornering the Track mode, stiffest of the three, was what we switched to for the best results gripping through the turns,
With the first-time-in-a-Mustang independent rear, we could not get the rear to skip over rough surfaces. Applying more power, which there is plenty of, could induce oversteer, but you can confidently control that by letting off of the throttle slightly to slot it back or just power out of turns if you dare.
There’s plenty of power with both the EcoBoost and V8, with a slight amount of turbo spool before the power kicks in for the EcoBoost, whereas the V8 is always ready and waiting. We would run up to the rev limiter occasionally which eases the rpm’s back as opposed to cutting out.
Let’s be honest; as much as we like the Ecoboost and the idea of a stompin’ little 4-banger, nothing sounds quite like a V8—and as superficial as this might sound, we have to have a V8 if for no other reason than it sounds like it means business. Shifting was precise and comfortable, as were the leather Recaro seats, and we liked the interior layout, preferring the toned-down engine-turning on the GT version.
Our V8 Mustang was the GT Premium that included 20-inch aluminum wheels with P265/35R hides, the subdued blade decklid spoiler, rear diffuser, aluminum foot pedals, and lots of other electronic and appearance features.
OK! Talking to Tom Barnes, Mustang Vehicle Engineer Manager, we pried to find out what was in the works for future Mustangs. He didn’t budge. Much. With the 2015 Mustang featuring aluminum hoods AND front fenders, we were curious about the switch to all aluminum bodies that the new F150 is seeing, and whether this might be in the cards for Mustang. He told us that Ford did develop an aluminum decklid and doors, but based on their myriad development targets, they went with keeping the aluminum stampings to the front fenders and hoods.
There were some manufacturing hurdles to making the aluminum fenders—especially with the point that ties into the headlights, but the engineers were able to remedy that. And Tom was quick to point out that even though the 2015 Mustang comes in a little heavier than the previous version, they took a lot of weight out of the front and rear suspension with the use of aluminum, along with using less material and lightening holes for things like the engine sub-frame and even things like excessive fastener lengths.
We spoke with a couple of the engine engineers and found that the change in this engine from previous 5-liters comes primarily in the intake and exhaust valve size. They both increased size from 12 mm to 13 mm each. Head porting and configurations were slightly improved, too. And the new composite intake manifold features charge motion control valves to partially close port flow at lower engine speeds. This increases the air charge tumble and swirl for improved air-fuel mixing resulting in better fuel economy, idle stability and lower emissions. It replaces the commonly used butterfly opening, and when the port is closed it is seamless and almost not tactually detectable, which composite construction brings.
When we brought up the Challenger Hellcat, the engineers pretended they didn’t know what that was. Upon further prodding they indicated they would likely leave the horsepower numbers to Dodge and instead consider looking at Mustang more from improved overall track and quarter mile numbers to the Hellcat’s. Putting two-and-two together this is saying that less weight and better handling could trump the higher horsepower numbers of the Hellcat—but they are always bound to their script and are not allowed to discuss Ford’s possible forays into the future. And about the future Barnes told us that he feels that the market insists on a V8 in all Mustangs into the future, in case you were worried that the EcoBoost would someday displace the might V8.
Ford has a bagful of model spinoffs to spice up the Mustang as it moves forward, like Super Snake, GT 500, and Boss 302 to name a few, and we can only imagine the improvements awaiting future iterations of this new Mustang, but make no mistake; the 2015 Mustang launches the modern muscle car into new and exciting territory. We can only hope that the next Camaro and Challenger will show as much swagger and sophistication as the 2015 Mustang.
OppoLock
RWD Addict
St. Petersburg, FL
Sean
'15 GT, '20 GT350
". . . Three suspension settings are available; Sport, Sport+, and Track, at the flip of a toggle, and there was a noticeable difference with each successive mode. Sport was the mild mannered setting, which we found most comfortable on the crappy asphalt roads on and around Mulholland Drive. But for cornering the Track mode, stiffest of the three, was what we switched to for the best results gripping through the turns. . ."
Tony Alonso
Super Moderator
Moderator
Cincinnati, OH USA
'01/'09/'19 Bullitt, '90 GT, '00 Corvette FRC
I sent an email to the article author regarding the comments on adjustable suspension using the driver modes. Perhaps he will respond.
It seems a few of the reviewers are getting confused about that capability.
200MPHCOBRA
Liberty Tree Needs Water
Louisiana
Greg
2013 BOSS 302
12 to 13 mm must refer to camshaft lift not valve size....hell of an error for a hotrod article.
Chlocli
Austin, TX
1999.5 Audi A4 1.8qtms
Reviews by these amateur drivers are worthless. We really need Randy Pobst to drive it. Motortrend has been testing the M4 and others including the S550 to determine the best driver's car of the year. Can't wait to see the results.
foghat
Calgary
2015 GT w/PP
The kicker is, one could maybe (just maybe) excuse that they just got mixed up with what the drive mode toggle does, but to claim that there was noticeable difference in the suspension in each mode?? Ya, I give this review 0 credibility after that.
Tim Hilliard
Happy Owner
Boston
'15 Guard 300A PP Recaro
WOW. So this was written by a 'gearhead' mag...interesting.
Show of hands: How many of you were concerned the EcoBoost was going to replace the V8? Goes to show you, just because you studied journalism, doesn't make you a journalist.
It's difficult to read ADD articles. It's written like a political piece. Lots of words, no content. Score -1 (MT already scored a 0, it's since been shown their take on the chassis is completely wrong)
Tim Hilliard
Happy Owner
Boston
"He told us that Ford did develop an aluminum decklid and doors"....the clean sheet re-do already paid for all the parts coming....
Tim Hilliard
Happy Owner
Boston
"We’ll give you the quick rundown on the handling, but then we’ll fill you in on what the Mustang Manager and lead engine engineer told us about some of the unspoken features you’ll want to know about" OK we're still waiting.
Spartan
MD
Ford Explorer Sport
Not sure why they didn't do this especially knowing "Weightgate" was coming. They must be saving this for the 2016 where they can claim some weight loss.
