Steeda Wants Your Feedback - New Parts Suggestions
tj@steeda
Timothy
Hello All:
Steeda would love to hear your feedback & suggestions for new parts you think we should bring to market.
With manufacturing facilities in Valdosta, GA ... we design, engineer & manufacture our parts right here in the U.S.A. ... making anything possible!
We look forward to your suggestions & feedback!
Best Regards,
TJ
JuRuKi
SoCaL
2016 GT/PP
Rear diffuser!
Warhead
South Carolina, USA
Warren
2015 Mustang Ecoboost Premium
Intercooler
Billet dress up cap covers (with all those lathes, it should be an easy business for Steeda to enter)
Auto shift ball kits
CVCashmere
South Jersey
Carl
15 GT Vert w/Steeda lower brace, PP sways & susp
Jacking rails that can be used to reinforce the chassis by having holes drilled in them with self-tapping screws that help it adhere to the body along its length. That, along with an adhesive might strength the body.
Especially useful for verts.
CVCashmere
chrisgonzales
Birmingham, AL
2016 Magnetic [wrap'd grey] GT Premium PP
Some type of handle situation for closing the rear trunk from the inside something that will last, i had one of the pulls that uses the clips space but it busted after long while
DANA44
Central Connecticut
2016 v6 convertible
Aluminium blocking to raise manual passenger seat height. The seat is too low. Anodize it black
lemers
Globetrotter
Carlisle, PA
2016 GT350
A rear spoiler that uses the same holes as the GT/GT350s
Wally-Bob
Pompano Beach Florida
Wally-Bob
2015 GT Prem PP 50AP
TJ,
We need a differential oil cooler.
An air intercooler is the conventional approach but does have placement constraints, rear diffuser requirements with ducting and fan concerns. An alternative would be an engine water intercooler allowing for more flexible mounting constraints, smaller sized intercooler and probably lower production costs.
Wally-Bob
Wally-Bob
TJ,
Spherical bearings for the front control arms.
Perhaps even a new control arm specifically designed for vehicles with your lowered ride height performance springs.
WildFire
West Virginia
Roger
2015 Mustang GT Convertible
Steeda Cold Air Intake (555-3193)
Your message to the Mustang community states “With manufacturing facilities in Valdosta, GA ... we design, engineer & manufacture our parts right here in the U.S.A. ... making anything possible!”
My Online Question to Steeda- A few months ago my wife purchased the Steeda Cold Air Intake (555-3193) for my 2015 Mustang GT Convertible. Now that it is getting warmer I noticed that the inlet temp is much higher during slow driving or while at stop lights. For example yesterday the Inlet Air Temp shows 158 and the Outside temp showed 89. Once the car got up to highway speeds for about a mile the Inlet Air Temp temp went back to within a few degrees of the outside air temp. I think that the CAI seal is not sealing properly and is allowing hot engine temps into the CAI box. Does Steeda have a taller seal that would help seal the CAI box thereby reducing CAI inlet temps? If not any suggestions?
Steeda Response- Hey Roger, the IAT will always be higher and rising when the car is at idle or sitting still. Once you get moving it should cool on down. That is normal functionality of a CAI. Nothing seems to be wrong with what you have explained to me.*
My solution was to purchase a small trash can from Home Depot cut it and then use adhesive / sealant with rivets to fill the gap. I also opened up a few of the hex holes in the grill.
In my opinion, it doesn’t look too bad. Now my inlet temperature does not rise that high(even at idle) and cools much quicker when driving.
If anything is possible, my proposed solution is that Steeda could design and sell a new CAI that will seal against the hood insulation. Additionally Steeda could design and sell a tall bulb type seal kit or other solution that current Steeda owners could purchase to seal the CAI from the hot engine bay.
Gurjit
B.C. Canada
2016 GT Premium performance pack
TJ,
I second this suggestion.
bbudman
Clayton, NC
Buddy
2017 GT350
Kind of corny I know but something to dress up the factory coil covers and engine cover. For instance the "Powered By Ford" letters. Maybe some billet letters to fit in to the factory coil covers. Offer them in various finishes, colors, etc. Also matching inserts for the engine cover as well as coil covers to fit in the indentations running front to back.
I myself thought about replacing the covers and going with carbon fiber or some other sort of dress up item but I kind of like the factory color especially on my Magnetic GT.
