2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com 46 - Roush Performance - 3
Homepage Wiki MOTM Register Search Today's Posts Mark Forums Read Ford Bronco Forum Calendar Garage
Go Back   2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com > Technical Subforums > Infotainment and Electronics (Nav, Audio, Video, Bluetooth, Alarm)
Infotainment and Electronics (Nav, Audio, Video, Bluetooth, Alarm) For all infotainment and car audio/video/phone/alarm discussions.
User Tag List
Reply
Thread Tools Search this Thread Display Modes
Old 04-26-2017, 10:41 AM   #1
Fenix
Drives: 2016 GT Premium Shadow Black
Thanked: 38 Times in 33 Posts
iTrader Score: 0 reviews
JL Stealthbox Install - Tips and Tricks
Installed the JL Stealthbox and JL XD300/1v2 Amp... WOW does it sound good! A little bass really evens out the stock system.
Just wanted to make a thread with some tips for those who are looking install the stealthbox.
My car is a premium so I decided to go the route of grabbing signals pre-amp. It was easy enough to get to in the drivers foot well. To do this I purchased the Molex connectors that are used in the factory audio harness (Thanks @mumbles !). The harness is really just a pass through, all pins are loaded, and has female RCA's spliced in for the amp signal input. The RCA is ran from the kick panel, down the driver side sill to the trunk. Connectors and pins I used for the harness are below.
Running the power cable is pretty straight forward, I used the grommet in the passenger side wheel well like a lot of guys do. Basically get the car off the ground and remove the passenger wheel well liner and the grommet is right there. Lucky me a buddy has a lift (and a '66 Fastback). I put some butyl rope on the cut grommet to seal it up. Also wrapped the cable with Tesa tape for a factory look. Once the rear seat was removed by depressing the two clips under each seat, I followed the factory harness into the trunk with zip ties along the way.
One tip I have for running the power wire is to attach a socket extension to the wire end. It helps a lot to have something to push through the grommet and past the insulation and carpet.
The ground is the same as mike2017gt's thread. He has a great thread so check it out for more details. It uses the tie down bar for the spare tire or inflation kit. The thread size is M6x1 and utlizes the left side thru hole. Just grind the e-coat away and clean it up with some alcohol. I used a lock washer to secure the terminal.
I tapped into the back up camera power wire for my 12v remote signal. It is a blue with white stripe wire found under the rear passenger speaker harness. Easy enough to get to. I was originally going to use the factory amp remote but discovered it was on a different connector (I think it was in the brown one if you look at the amp). It's 6v if anyone is wondering. The JL XD300 amp turns on right at 6v.
I searched for where guys were mounting the remote level control for the sub and there were a lot of different places. I eventually settled inside the console as it was out of sight and easy to get to if I needed to adjust the sub. I decided to remove the 12v plug and re-purpose that hole for my level control. The whole panel that houses the USB port and 12v plug just pops right out. The plug itself was kind of a pain to remove even though it's just held in there with a couple small tabs. I cut a small hole under the console carpet and the phone wire for the part just runs under the carpet back to the trunk.
Installing the stealthbox itself is a complete pain in the ass to be honest. The thing is so tight I had to grab a prybar, wrap it with electrical tape, and have a buddy pry it around until all the holes lined up. The instructions say to just "Guide it in place"...yea guide it with a pry bar! Other than that part the install manual is spot on and everything ended up fitting really nice.
Overall the install wasn't too bad. I'd say it took 6 hours total. Some of that time I spent wrapping the power and ground cables with Tesa tape to make everything look a bit cleaner. The sub is paired nicely with the 300W JL amp. I thought it would be a bit under powered but it really sounds great.
__________________
FRPP Strut Tower and Cowl Brace, FRPP Catch Can, Magnaflow Street, JL Stealth Box and JL XD300/1v2 Amp, 35% SunTek Ceramic Tint, Big Worm Gun Smoke Tinted Tails
Fenix is offline   Reply With Quote
Users thanking this:
Old 04-26-2017, 10:46 AM   #2
Fenix
Plug List
Male Plug:
http://www.mouser.com/Search/m_Produ...66vcbDVA%3d%3d
Female Plug:
http://www.mouser.com/Search/m_Produ...x?R=34690-0160
Pins:
http://www.mouser.com/Search/m_Produ...sV%2f%252bo%3d
__________________
Old 04-26-2017, 10:55 AM   #3
scott_0
scott_0's Avatar
Drives: 2016 Mustang GT
Thanked: 264 Times in 212 Posts
iTrader Score: 2 reviews
nice job, awesome write up!
__________________
2016 DIB GT Premium A6, Borla S-type axle backs, Mishimoto h-pipe, JLT intake, Lund tune, SVE GT350 wheels 19x10/19x11, 2016 PP struts and shocks, BMR springs, Maximum Motorsports CC plates
scott_0 is offline   Reply With Quote
Old 04-26-2017, 11:55 AM   #4
Jmeo
You said member ;)
Jmeo's Avatar
Drives: 2017 Premium A6 Magnetic
Thanked: 1,558 Times in 1,002 Posts
Garage
iTrader Score: 16 reviews
May I ask what the use is for these? Is it a way to seamlessly grab a remote turn on lead for the amp?
__________________
17' GT premium A6: Whipple, Steeda, Airlift 3H, Kooks, Magnaflow, Borla, Roush, Ford Racing, Mishimoto, WMG, Trufiber, Diode Dynamics, DSS, Brembo, G-Loc, Saleen, GlowShift,
GTFOSquad #0052
Instagram: jmeo291
Facebook Group https://www.facebook.com/groups/499781586894652/My build thread http://www.mustang6g.com/forums/showthread.php?t=66890
Jmeo is offline   Reply With Quote
Old 04-26-2017, 11:57 AM   #5
Jmeo
You said member ;)
Jmeo's Avatar
Garage
Very nice write up I thank you very much. I absolutely love the harness you found to grab RCA signal. Would you be able to provide a link for this?
Ingenious idea for the bass knob
Thanks again
__________________
GTFOSquad #0052
Instagram: jmeo291
Old 04-26-2017, 12:17 PM   #6
Fenix
Quote:
Those connectors are what I used to make a pass through cable. I soldered in the RCA's to the right rear speaker wires in my harness. Check out the sticky for pin out info.
The remote turn on is easiest to grab under the rear passenger speaker. It's a blue wire with white stripe, 12v ignition on, 0v ignition off.
__________________
Old 04-26-2017, 02:33 PM   #7
mumbles
mumbles's Avatar
Drives: '16 GT Prem OW
Thanked: 231 Times in 200 Posts
Awesome job and writeup!
__________________
2016 GT Premium Fastback
Performance Pack / 6MT / 401A / Reverse Park Assist / Security Pack / Voice Act Nav
Stance SF03 20x10 +35 square / BFG g-Force COMP-2 A/S 285/35ZR-20
http://i1206.photobucket.com/albums/bb460/eirvin60/6G-Mustang-Design-Sketch-Scaled.jpg
In the universe of bad drivers, I am the Sun...
mumbles is offline   Reply With Quote
Old 05-25-2017, 11:41 PM   #8
BlackS550
BlackS550's Avatar
Drives: 2015 black s550 PP
Thanked: 107 Times in 81 Posts
great writeup , it looks awesome too!
im getting my stealthbox and phoenix gold sx2 amp installed on tuesday, i cannot wait
__________________
401A PP | JL Audio | Corsa | Eibach | Steeda | Brembo | BMR | Airaid | UPR | Moroso | TruCarbon | Maximum MS | Ford Performance | Bel STi-R Plus | Michelin
BlackS550 is offline   Reply With Quote
Old 06-10-2017, 04:53 AM   #9
BlackS550
BlackS550's Avatar
couple questions
do you have any issues w over heating w the amp installed there?
did u have any issues with active noise cancellation messing with your audio or turning your amp/bass lower?
@Fenix
__________________
Old 06-10-2017, 07:25 AM   #10
Fenix
I have not had any issues with the amp overheating. I had that concern initially but it seems to be fine. I went on a 10 hour (one way) road trip recently and the stereo was blasting the whole time so if it would have overheated I'd like to think it would have done it then.
I haven't noticed any funky stuff going on with the active noise canceling but honestly I'm not sure what it does in the car. The bass seems to stay where I put it
__________________
Old 06-10-2017, 01:10 PM   #11
BlackS550
BlackS550's Avatar
I think this sentence just solved all my problems...
"My car is a premium so I decided to go the route of grabbing signals pre-amp. "
took it back to install shop and theyre like yea theres two ways we could wire it, and we didnt do it that way. theyre re-wiring it right now and think that should solve my issue (when motor is on, amp/bass cut out.. when motor is off, sounds fing amazing)
__________________
Old 06-10-2017, 04:20 PM   #12
Fenix
Did they use a line out converter to grab signals after the amp?
__________________
Old 06-11-2017, 01:12 AM   #13
BlackS550
BlackS550's Avatar
Quote:
if thats the wrong way to do it... then yes lol
they got it fixed now thankfully
__________________
Old 06-11-2017, 08:49 AM   #14
Fenix
Nice, glad to hear it got resolved!
__________________
Old 06-15-2017, 11:38 AM   #15
floydbanks28
floydbanks28's Avatar
Drives: 2016 eco boost premium
Thanked: 0 Times in 0 Posts
Thanks for the info, I just bought the connectors you suggested to make the pass through. Great write up wow. Life saver man. Any way you could go into more detail about how you made the pass through cable?
__________________
2016 EB Premium, Manual, FP procal performance package, 3.73 rear end swap,
Winter: 98GT full bolt on, manual, Icexi3's 235/35/16 all around, 2007 base v6 rims,
floydbanks28 is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Tips and tricks for slicks? armykyle1 Dragstrip and Launching 16 02-13-2017 02:37 PM
ProCharger install tips and tricks Bartly Forced Induction - 5.0L V8 Engine 87 11-30-2016 12:09 AM
Any special tips or tricks for header install? Csb1992 V8 5.0L Engine / Mods: Bolt-ons, Exhaust, Tuning 17 11-11-2016 06:31 PM
MGW shifter install tips and tricks Blackbeauty Transmission & Drivetrain 3 05-29-2016 10:49 AM
Airlift V2 Install Tips n Tricks? ven377 Suspension, Brakes & Chassis 2 02-26-2016 11:20 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.2.4 (Lite) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.Navbar with Avatar by Motorradforum
Garage vBulletin Plugins by Drive Thru Online, Inc.
