Racemaster
- Jun 2, 2016
- Long Island,NY
- Website
- www.skspeed.com
- Jeff
- 2015 Roush 2003 Marauder
Here is a clean way to get rca cables from the factory harness without cutting and splicing anything.All parts are sourced from mouser electronics.
First,you need a molex 34691-0160.It has 90* pins that are longer.
You can cut off the bottom row,as we only need the long top one's.
Next ,strip back your rca cables and tin the ends.My amp is in the stock location so I am using male ends.You guys may have amps in the rear,so you use a female end cable to attach to what you ran from the back.
We are going to use the same pin from molex that goes in the male side of the plug.Part #34803-3212.
This is a $25 crimper from ebay.
Solder the pin on after crimping.Do not get solder up in the slot where the pin goes.
Next,shrink sleeve the pins with 1/8" tubing leaving about 1/16" exposed.
This leaves some of the pin exposed to solder after the are installed.I braided the bundle to make it neat.
Next is install the plugs on the pins.
After you verify they are correct,solder the bare end.It does not need alot.It will also keep the pins from pulling apart.Forgot to take a picture of that part.I then coated the assembly with liquid electric tape.
Then shrunk a piece of 1 1/4" shrink tubing over the plug.
Hope this helps some of you guys doing your own installs.Plug and play!
