smokinzx14r
- Mar 2, 2015
- ST Petersburg FL
- Lee
- 2015 GT A6 3.55 Gears ..
I posted this in the mod and tune thread also but I was thinking one of you guys that drag race a 2015 GT M6 might have a answer to my on going problems at the drag strip ..Here is the post ..
Ok I'm still having problems ... Traction control OFF , Advanced Traction control OFF ,
Same problem .. Leave the starting line at anything above idle the car will pull hard for a few feet and then the motor loses ALL power and falls back to 1000 RPM.. Feels like you are pulling a 10,000 pound trailer or the Brakes are FULL ON .. It takes forever for the engine to rev up to 6500 RPMs .. As soon as I shift to second gear all the power is restored ..Second gear , third and four gears are fine , it pulls like a bat out of hell .. This only happens in first gear ... Now if I leave at Idle it doesn't do it ... But now it has started a new problem . If I leave at idle and then punch it after full clutch release it pulls very hard till it hit around 5500 and then it loses all power ... Shift to second and power is restored and pulls all the way to 7k and never noses over ..
So we have 3 things going on here , Traction control , Advanced Traction control and clutch protection mode ... Bama tells me that my flash ( all their flashes ) have the clutch protection mode turned off and that mine is turned off .. My Traction control is turned off .. I press the T/C button and hold till the Advanced Traction control window pops up and it said Advance Traction control off and I hit ok , even if I don't hit ok it still does it .. This is what I have been told to do to turn off both the T/C and Advanced T/C ... I have also done it by the owners manual ... So I have tried to both ways many many times and it still does the same thing ..
I am really lost here .. Either Bama didn't turn off the clutch protection control like they said or I have a different problem that might be in the T/C or Advance T/C system .. I did run that one 12.78 leaving at idle a few weeks ago , but leaving any harder it loses all power in first gear and runs high 14s ..
I'm ready to take a 10k loss and trade the damn thing in for a automatic car .. It just sickens me to be having this problem and not have an answer to the cause.. I can't race the car this way and that makes the car worthless to me .. I can't mod it and add any more HP to the car because that would be a waste of money .. I have to find the problem .. Please help ....
Lee ..
Lee ..
