The "what things weigh thread."
Status
Not open for further replies.
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
2015 Mustang Component Weights
Making a list here. Will have more parts soon - just needed to start keeping track!
OEM PP Shock Tower Brace: 7.6lbs
OEM PP K-Brace: 10.4lbs
OEM Front Subframe (K-Member): 58.2lbs
BMR Street/Handling K-Member:
BMR Drag K-Member:
Watson Racing Drag K-Member & Arms: 42lbs
OEM Rear IRS Subframe (Empty): 55lbs
OEM IRON Diff Housing, Loaded - No Fluid: 99lbs
OEM IRON Diff Housing, Bare/Empty:
OEM Aluminum Diff Housing, Loaded - No Fluid: 77lbs
OEM Aluminum Diff Housing, Bare/Empty: 16.64lbs
OEM IRS Halfshafts: 21.1lbs/each
FRPP Halfshafts: 31lbs/each
GForce Halfshafts: 31lbs/each
OEM Iron Diff Loaded, Halfshafts, Inner/Outer Stubs - NO Fluid: 158.5lbs
G-Force 9" Diff Loaded, Halfshafts, Inner/Outer Stubs - NO Fluid: 163.2lbs (4.7lbs gain to do a 9" GForce Swap)
OEM Rear Lower Control Arm: 15.24lbs - each
OEM Rear Upper Camber Link Arm: 5.0lbs - each
BMR Billet Fixed UCL: 2.22lbs each
BMR Adjustable UCL:
Steeda Billet Fixed UCL: 3.0lbs each
Steeda Adjustable UCL:
OEM Vertical Link: 3.2lbs - pair
BMR Billet Vertical Link: 3.2lbs - pair
OEM Rear Toe Link/Rod Arm: 2.42lbs - each
BMR Adjustable Toe Rod w/ Lock Out Plate:
OEM Rear IRS Cradle Mount Bushings: 1.05lbs - each
BMR Delrin Cradle Mount Bushings: .50lbs - each
OEM Rear IRS Diff Mount Bushings: .90lbs - each
BMR Billet Aluminum Diff Bushings: 1.47lbs - each
OEM Rear Lower Control Arm Bushings: 1.1lbs - each
BMR RLCA Bearing Upgrade Bushings:
OEM EPAS Rack: 36.46lbs
OEM Motor Mounts: 7.8lbs - pair
BMR Adjustable Motor Mounts: 3.8lbs - pair
OEM Windshield Washer Fluid Res. w/ Fluid: 9lbs
OEM Battery: 31.31lbs
Deka ETX18: 17.67lbs
Anti-Gravity YTX12-24: 5lbs
Anti-Gravity YTX12-20: 4.5lbs
Anti-Gravity YTX12-16: 4lbs
OEM Catback Exhaust: 72lbs
Magnaflow 3" Comp CB: 44lbs
Corsa 3" Sport CB: 61lbs
Bassani X-Pipe CB: 38.4lbs
OEM Axle Back Exhaust: 38.4lbs
Pypes Touring Axle Back: 20.4lbs
OEM "Mid Pipes" w/ Cats: 22lbs
MAK O/R Pipes:
OEM Resonator "Suitcase": 17lbs (others report 22-23lbs)
CJPP H-Pipe Res. Delete: 10.5lbs
SR Performance X Pipe Res. Delete: 9lbs
OEM GT/V8 Passenger Side Header: 10lbs.
OEM GT/V8 Driver's Side: 19lbs
Borla GT/V8 Longtube Headers: 14.2lbs per side
OEM Base 18" GT Wheel w/ Tire: 54.5lbs
OEM PP Model 19" GT Wheel w/ Tire: F-60.6lbs / R-64.3lbs
OEM Dark Stainless Painted Aluminum 19" x 8.5" Wheel w/ Tire: 57.6 lbs
OEM Foundry Wheel w/ Stock Tire: 55.2lbs
OEM Foundry 20" Wheel w/ Tire: 64lbs
OEM Premium20x9 Foundry Wheel: 35.7 lbs
OEM GT PP Front 9" Wheel: 32.5lbs
OEM GT PP Rear 9.5" Wheel: 32.4lbs
Billet Specialties 17x4.5 w/ MT SR 28" Radial: 39.8lbs
Racestar 17x4.5 w/ MT SR 26" Radial: 34.6lbs
Billet Specialties 17x9.5 w/ MT 28" Drag Radial: 51lbs
Billet Specialties 17x10 w/ Hoosier 28x10-17 Slick: 42.9lbs
Weld RTS 17x10 and Nitto 555 285/40/17: 50.4lbs
MRR M350 19x10 Wheel: 23.7lbs
HRE FF15 Wheels: Each
18x10 ET40 - 21lbs
19x10 ET40 - 22.6lbs
19x11 ET55 - 23lbs
20x10 ET40 - 24.2lbs
20x11 ET55 - 24.6lbs
OEM Lug Nuts: 12oz (per wheel, 5)
Titanium Lug Nuts: 3.5oz (per wheel, 5)
OEM GT Cloth Seat: 50lbs
OEM Cloth Recaro Seat: 50lbs
Corbeau FX1 w/ Bracket: 25.7lbs
OEM GT Base 14" Front Brake Kit (Rotor/Caliper/Pads): 43.8lbs per side (87.6lbs total L+R)
OEM GT PP 15" Front Brake Kit (Rotor/Caliper/Pads): 47.2lbs per side (94.4lbs total L+R)
Aerospace 13" Lightweight Street Brakes (Rotor/Caliper/Pads/Brackets): 19.4lbs per side (38.8lbs total L/R)
OEM GT Base REAR Brake Kit (Rotor/Caliper/Pads): 31lbs per side (62lbs total L+R)
OEM GT PP REAR Brake Kit (Rotor/Caliper/Pads) -
Aerospace DRAG Rear Brake Kit (Rotor/Caliper/Pads/Brackets): 12.2lbs per side (24.4lbs total L+R)
OEM GT 14" Base Front Rotor: 28.56lbs (57.12lbs pair)
OEM GT PP 15" Front Rotor: 33.4lbs (66.8lbs pair)
Aerospace 13" Lightweight Street Rotor: 14.3lbs (28.6lbs pair)
BAER Eradispeed GTPP Slotted 2-Piece: 22.8lbs (45.6lbs pair)
OEM GT Base Rear Rotor: 17.2lbs (34.4lbs pair)
OEM GTPP Rear Rotor:
BAER Eradispeed GT Slotted 2-Piece: 12lbs (24lbs pair)
OEM GT Base Front Caliper: 15.24lbs (30.5lbs pair)
OEM GT PP Front Caliper: 13.8lbs (27.4lbs pair)
Aerospace Lightweight Front Caliper: 5.1lbs (10.2lbs pair)
OEM GT Base REAR Caliper: 13lbs (26lbs pair)
OEM GT PP REAR Caliper:
Aerospace 2 pot DRAG REAR Caliper:
OEM Front "base" Sway Bar: 12.7lbs
OEM Front PPGT Sway Bar: 14.5lbs
FRPP Track Front Sway Bar: 15.5lbs
OEM Rear "base" Sway Bar: 4.4lbs
OEM Rear PPGT Sway Bar: 4.5lbs
OEM GTPP Front Strut:
OEM GT Base Front Strut:
Koni Yellow Front Strut: 10.3lbs each
OEM S550 Front Strut ASSEMBLY - "Complete" (strut, spring, strut mount): 19.40lbs / per side
VikingFront Coilover Kit ASSEMBLY w/ Sway Bar Mounts - Complete w/ BMR CC Plates: 15.90lbs / per side
OEM GTPP Rear Shock: 4.5lbs
OEM GT Base Rear Shock: 4.5lbs
Koni Yellow Rear Shock: 4.9lbs each
OEM Front V8/GT Coil Springs: 4.8lbs - each
BMR Drag Front Springs: 3.95lbs - each
BMR Performance Front Springs: 4.8lbs - each
BMR Min Drop Front Springs: 4.75lbs - each
BMR Handling Front Springs: 4.8lbs - each
OEM Rear V8/GT "base" Coil Springs: 9.7lbs - each
OEM Rear GTPP Coil Springs: 8.5lbs (reported for '17 MY)
BMR Drag Rear Springs:
BMR Performance Rear Springs:
BMR Min Drop Rear Springs:
BMR Handling Rear Springs:
OEM Front Sway Bar End Links: 1.6lbs pair
BMR Adjustable Front End Links: 2.2lbs pair
OEM Front Bumper Bar: 11.2lbs
BMR Front Bumper Support: 2.8lbs
OEM Rear Bumper Support Bar: 16lbs
BMR Rear Bumper Support Bar: 3.4lbs
OEM 2-Piece Driveshaft / Auto: 29lbs
OEM 2-Piece Driveshaft / Manual: 36.2lbs
Shaftmasters Auto 1-Piece Aluminum DS - 19lbs
Shaftmasters MT82 1-Piece Aluminum DS - 18.73lbs
Dynotech MT82 1-Piece Aluminum DS - 17.4lbs
DSS Auto 1-Piece Aluminum DS - 27.6lbs
DSS Auto 1-piece Carbon Fiber DS - 24lbs
OEM Front Spindle/Hub Assembly: 19.3lbs each
OEM Front Spindle - Bare: 12.19lbs each
S197 Front Spindle/Hub Assembly: 16.25lbs each
OEM Front Control Arm: 4.3lbs each
OEM Front Radius Arm: 6.8lbs each
OEM Front Tie Rod: 2lbs each
OEM Tire Air Pump: 5lbs
OEM EVAP Module/Canister
OEM Engine Sound Tube: 1.3lbs
OEM Engine Coil Covers: .75lbs/each
OEM Engine Cover: 3.4lbs
OEM Battery Cover: 1.23lbs
OEM Plastic Trunk Latch Cover: 2.40lbs
OEM Rear Seats: 30.8lbs
OEM Rear Lower Seat Cushion: 11lbs
OEM Trunk Carpet Cover: 4.6 pounds.
OEM Stock Floor Mats: 2.6 pounds.
OEM Carpet / Complete: 16.5lbs
OEM S550 BARE Hood: 31lbs
OEM S550 Loaded Hood: 36~lbs
Trufiber Carbon Fiber (Lightweight) Hoods: 17lbs
Trufiber Carbon Fiber (Standard) Hoods: 30lbs
Trufiber Fiberglass Hoods: 40lbs Anderson Composites CF Hood: 22lbs
2015 Mustang GT Performance Pack 300A - MT82 Transmission
Curb Weight (scaled at BMR) - 3736lbs
Front Unsprung Weight: 143.9lbs per side
Rear Unsprung Weight: 132lbs per side
2015 Mustang GT Base 300A - 6R80 Automatic Transmission
Curb Weight (scaled at BMR) - 3704lbs
***AFTERMARKET "ADD-ON" PARTS (parts that the vehicle is not equipped with from the factory)
Chassis Jacking Rails
BMR CJR001: 21lbs
BMR CJR002: 13.76lbs
Steeda Ultra Lite: 12lbs
jayman33
Fort Bragg, NC
Jason
24 GT
Well there you have it, you'll have broken half-shafts in no time!! lol
BMR Tech
BMR Tech
Tampa, FL
Dion
Wow. The Aerospace Lightweight Street Kit is looking like it is going to save some serious weight!
ilkhan
435 ilkhan approved HP.
Reno, NV
[Gone 2016 400A] > 2017 F150
Can you clarify if that OEM catback is V6/EB/GT?
Also needs premium/leather seat weights.
Fixed
BMR Tech
BMR Tech
Tampa, FL
Dion
Also needs premium/lather seat weights.
Fixed
Fixed the Catback weights.
dubster99
Nor*Cal
2015 Ingot Silver GT PP
How about wheel weights minus tires?
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
The PP wheels about 33-34lbs each. There is a .5lb difference between the front and back.
Mikeiscoo2
Fort Myers Fl.
mike
2015 Mustang GT
Items thus far.
Rear Seats- 30.8 pounds.
Trunk Carpet Cover- 4.6 pounds.
Battery Cover- 1.4 pounds.
Stock Floor mats- 2.6 pounds.
Single carpet piece that connects to rear seat- 0.8 pounds.
Total at this Point - 40.2 pounds.
Chameleon
Gold Sponsor
S550 INTERIOR DRESS UP
www.ebay.com
Good info.
drabon74
Conway, SC
2018 GT Premium 401a
How much does that sound tube weigh that lots of people are removing? How about stock vs recaros front seat?
Status
