Yet Another Wheel Bearing Question
TicTocTach
DFWTX
Clair
2018 EBPP
I'm getting some noise from the rear axle area of my 2018 EBPP that sounds like wheel bearings. There is also a bunch of slop in the driveshaft at the pinion bearing area, but it seems like that is mostly a clang/clunk sound when going from R to D or when downshifting. At first I thought the wheel bearing noise was tire noise, but I can feel a the rear wheel move when the car is sitting on all 4's in the garage and grabbing the tire at 12 o'clock. and pulling/pushing.
Took the car to Local Dealer this morning and they came back with "the noise is tire wear, and the slop you feel is actually inside the differential - it's a floating axle and that clicking is in the spider gears."
I'm calling BS.
This car has the Torsen diff, so there wouldn't be any noise from "spider gears", and the tires have been on the car for a couple years now with a relatively conservative alignment - about the same as GT350R alignment - Front -2.0* camber & 0.01* toe in; Rear -1.5* camber and -0.11* toe in. There is a little wear on the inside of the tires as you'd expect, but still plenty of tread across the tire. Seems like bearings going out would also lead to increased tire wear.
So what is the real deal with Mustang wheel bearings, and when do you know they are going bad? I'm used to hearing the droning / howling noise and feeling the play like any other bearing I've dealt with over the last 40 years of working on my own cars. I have an extended warranty on the Mustang and I don't want to do this work if I don't have to.
TicTocTach
TicTocTach
DFWTX
Clair
2018 EBPP
Small update - took this video after a few minutes in the garage today. Not sure how they could claim having tested all 4 wheels without noticing this…
daSNAK3
Cary, IL
Jake
2021 GT
I would be furious, bring the car back along with the video and start some shit... lol
I feel like dealers don't even try anymore.
Crackerjack17
WV/Maryland
2017 GT PP
Take the wheel off and try and tighten the nut? Wheel bearing is easy to change if you have the tools.
TicTocTach
TicTocTach
DFWTX
Clair
2018 EBPP
I plan to go full social media on them as well as sending the video to the service manager as another reminder of how crappy their mechanics are. I'm also going to get the parts in the mail and do the job myself. It was weeks for me to get an appointment to just look at the problem with Local Dealer, and the next closest has 2-star reviews online for much of the same behavior. I just don't know what kind of business model that is...
noGreta!
2025 Lexus IS500 F Sport
Sorry to hear your troubles OP, these crooks now only understand one language: lawyer talk. When it comes to recalls and warranty work:
"They are the No. 1 problem at Ford right now. And it's the worst in the industry when it comes to recalls and warranty work," said John McElroy, a longtime industry observer and host of "Autoline After Hours" webcast and podcast. "It’s been going on for years and they haven’t solved it yet."
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Well if you can rock the wheel like that its 100% a bearing, but you knew that.
couple of times while under warranty, I paid out of pocket for known trustworthy shops to fix things which would have been covered under warranty, partly because the dealer near me is swamped constantly and I didn’t want to leave my car for 2 weeks for a 2 day repair (oil pressure sensor leak)
they couldn’t figure out my brake issues and it took extra time to get the ā€˜good’ mechanic’s eyes on it. Gives me pause buying another Ford although theres a lot I like about the company’s products.
TicTocTach
TicTocTach
DFWTX
Clair
2018 EBPP
The delay in service is a big part of the problem - 3 weeks to get the wheel bearing looked at, and November 29th before they can look at the driveshaft issue… then another 2-3 weeks for the DS repair…really?? The wheel bearing is small potatoes in the overall scheme of things, and the warranty is still there if something big comes up. Off to Ford Parts Giant, I suppose…
Keeffa
australia
keith
ford mustang 2018 gt
I had same knock on my 2018 I just tightened the hub nut, all fixed. Ford it would appear are usless everywhere. Hope not but!
Dana Pants
Burlington MA
Dana
2018 GT PP1
Because the axle nut thread is in the direction that launching the car will loosen it.
Threadlocker red + as tight as humanly possible is the ā€œbestā€ solution I have found.
  • Like
Reactions: GTP
Dana Pants
Burlington MA
Dana
2018 GT PP1
A 5 liter internal combustion engine is a pretty big impact gun hammer mechanism. Don’t think just glue.
Johnny Rockit
Massachusetts
Johnny
2022 Mustang GT 6-speed. 2015 F-250XLT,73 Torino
Someone should get fired for a fuck up like that.
NightmareMoon
good story, but many of us switched to good lug nuts very early and have always torqued everything properly since day 1. I’ve had 4 hub failures, mostly early on, and another forum guy who tracks a lot had 9!
Ford has been dealing with it on the parts side and the newer hub and nut model numbers don’t fail as quickly, whats why you’ve noticed a longer interval recently. The newer hubs and nuts are better quality.
also the reason you see more drivers side failures is that the axle nuts aren’t reverse thread on that side, so the normal torque from accelerating is in the ā€˜loosen’ direction. In that case checking it regularly probably helps.
