Would the gains be worth it?
Eric5.0
Omaha
Eric
2015 Mustang GT
Hi guys. I had big plans for my 2015 GT. Put money into a tremec magnum xl, 1,000hp mcleod clutch. Then I spun a bearing in October. Got a new block. I'm thinking about going from an 80mm pulley to a 69mm pulley and updating the tune. I haven't been on a dyno yet so i don't know where I'm at. Just trying to get an idea of what pulleying down on my setup below would do to see if it would be worth it. Thanks guys, I really appreciate your input.
Roush 2300 TVS supercharger
Lethal Performance Level 1 Return Style Fuel System w/ 2 Walbro 465lph fuel pumps
DeatschWerks EV14 DV2 Fuel Injectors; 95 lb.
Griptec 80mm pulley
Palm Beach Dyno E85 tune
JLT CAI, MAF 125mm.
Kooks long tube headers
Borla ATAK Axle-Back Exhaust
Gen 3 coyote block 12:1 compression with gen 2 heads and cams.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Like Jackson mentioned. Swap the pulley and log some WOT pulls. Watch your STFT's and lambda and spark.
80 down to a 69mm is going to be about 4-5psi on a 2300. It's going to surprise you. Be aware.
Eric5.0
Omaha
Eric
2015 Mustang GT
Thank you both.
Stephen@lethal
2020 Mustang Gt500
Griptec 80mm pulley
JLT CAI, MAF 125mm.
Like others have stated, you should be good to go with that setup, especially with the E85, the gains will absolutely be worth it and you definitely should be able to feel it.
Eric5.0
Omaha
Eric
2015 Mustang GT
With the JLT intake and kooks long tube headers there would be less boost pressure right? So that would help from a safety standpoint if im thinking about it correctly.
Cory S
Bradford, NH
Cory
Not hardly measurable no. Intake wouldn’t change anything, LT’s maybe drop .25psi
