Wiring for fuel pump connector
christian
Happy Member
Bellefonte, PA
2015 Guard GT
Going back to stock. Anyone have the wiring diagram so I can see what color wires go where on the female plug for the fuel pump? It's a 4 prong plug on the pump. I see a small green, small yellow with purple stripe.
Large white with purple stripe and a large yellow with grey. Thanks in advance!!
christian
Happy Member
Bellefonte, PA
2015 Guard GT
Looks right but I'm not good at reading....which one shows the actual connector that plugs into the fuel hat? Its 4 prongs and I dont see any 4's on that diagram. I know it's there but I cant figure it out lol
christian
Happy Member
Bellefonte, PA
2015 Guard GT
Here's the wiring coming from the harness
mustank
APO
2016 mustang gt
look at the C433 on the fuel pump. it looks like 2 separate connections, but it is pin 1,2,3,4.
lance5oh
Lance
2016 Mustang GT pp
I have been experiencing a P0627 code come and go and the car would sometimes act as if it were running out of fuel. I then removed the back seat to inspect wiring and the electrical plug and lines. I found this. I then trimmed that “tin” looking metal wire back to the loom so it couldnt make contact with anything… i dont believe it was doing anything in the first place. I plugged the connector back in and rerouted the wires so they wouldnt be pinched by the seat anymore. Now the car just turns over and doesnt not start. I didnt remove the negative terminal from the battery prior to doing so. Is that metal wire a ground? Or did i trip a fuse or relay? If someone could help id really appreciate it. I also depinned the yellow wire bc it was showing wire but havent repaired it yet… the 2 wires on the right of the plug were both showimg exposed wire
