Winter tires over PP1 19s, staggered or square?
RKRZ
Toronto, Ontario, Canada
2020 GT MT82 PP1 301A AE MR
Looking to cover the stock 19" x 9" (F) 19" x 9.5" (R) with Nokian Hakkapeliitta R3, since I hear narrower tires are better in the winter am I better off doing 255/40/19 squared all around or should I copy the standard profile of 255 front 275 rear?
kz
West Chester, OH
Mustangs & F150
Any particular reason why? Just trying to hear everything out since I didn't get any consensus talking to Mustang people IRL.
Doesn't really matter. If you had square set of wheels, I would definitely do square (in fact - it's what I've done - my "winter" set is 255/40/19 DWS06 on OEM non-PP wheels (19" / 8.5" wide I believe).
If you're using stock PP wheels, you won't be able to rotate, you will affect gearing by having shorter rear tire (it actually drives nicer with the tall 18+ gearing and I personally like it).
I would probably do square, narrower rear will help with traction in the snow.
EFI
Masshole central
5.Br0
That's what the car came with and is designed for, no real reason to go 255 on a 9.5" tire. It's not going to make a discernible difference in the snow over a 275.
