Willow Springs Big Track lap video
JBG0137
Calif
2016 GT350, 1965 Mustang Fastback, 2019 GT350r
Cobra club weekend at Willow Springs raceway, finally have all the Steeda suspension parts installed and it made a big difference on the corner handling.
VoR
San Diego
Vic
2022 Mustang GT
Looks like a lot of fun! I have been on that track a bunch, but on my motorcycle.
JBG0137
JBG0137
Calif
Steeda parts: On the rear end I have the Steeda Sway bar and links, billet mounts, rear subframe bushings, upper red isolation bushings, subframe to frame reinforced bars, lower arm spherical joint, Billet upper link, front end I have the Vorshslag camber plates, adjustable lower arm, Steeda large sway bar and billet mounts (bar set to middle hole), Steeda cross mount, I had the motor mounts but removed them. front camber was set to 3.5 after a few sessions I realized the right front needs less at Willow.
derklink
United States
Mach 1
Steeda parts: On the rear end I have the Steeda Sway bar and links, billet mounts, rear subframe bushings, upper red isolation bushings, subframe to frame reinforced bars, lower arm spherical joint, Billet upper link, front end I have the Vorshslag camber plates, adjustable lower arm, Steeda large sway bar and billet mounts (bar set to middle hole), Steeda cross mount, I had the motor mounts but removed them. front camber was set to 3.5 after a few sessions I reliz the right front needs less at Willow.
Good setup!
M1N
Temecula
Nick
2023 Mach1
That is really fast and a great time for that track! If you were with the Lynn Park cobra club I was there that weekend. Always a good time!
Flyhalf
CA
www.youtube.com
Alessandro
Mustang GT 18 10speed auto PP1 , GT500 '21
Cool fact. The track is now up to 2 seconds faster vs few months ago thanks to the repavement! Cant wait to go back.
I love willow springs. One of my favorite track FOR sure.
JBG0137
JBG0137
Calif
What splitter and wing do you have on your hotrod? Im putting together a track only 2019 gt350 now.
Flyhalf
CA
www.youtube.com
Alessandro
I make splitter and fast release splitter kits :)
Check speeditaliaracing.com
I also collaborate for Wings and diffuser with AJ hartman.
Feel free to DM me. And we can talk.
I love to help on this matter.
One note. For real aero you need coilovers or conversion kit (aj hartman makes one)to sustain the additional load and the fact the splitter is 3inchrs from the ground (otherwise you will destroy it)
The oem magnaride set up is not enough
I should be back first months of 2024.
I really hope i can get close to 1:21.
Alessandro
WItoTX
Houston
Kyle
'17 GT350
Alessandro
I will chime in here. I have his coil over conversion, on 400 lb springs. Granted I need to stiffen the shocks up a bit, I still had the splitter scrape last weekend. My personal opinion, to make full use of his kit, one really needs the DSC.
Also, I think I just received the same wing as you. Installing on Thursday. Very pumped because this past weekend was rough with a splitter and no wing.
Flyhalf
CA
www.youtube.com
Alessandro
Makes sense. I'm for coilovers when aero becomes a real thing.
If you need titanium skids for splitter protection..
Speeditaliaracing.com
JBG0137
JBG0137
Calif
Alessandro
PM me when your back
