Will these work with a GT PP?
5pointOh
Jax, FL
2019 GT PP1 Ingot Silver "Millennium Falcon" @falcon_s550
They are GT performance pack replicas but the site says they wont work with upgraded brakes. How much spacer would I need to run in the front if any to run these all the way around?
Wheel Size 19x10
Wheel Offset 35
Bolt Pattern 5-114.3
Hub Size 70.6
Back Spacing 6.88
Center Caps Center cap included, factory center cap with 2.5" lens will interchange
5pointOh
Jax, FL
After searching it seems like these should be fine with the +35 offset.
wildcatgoal
@sirboom_photography
TBD
Offset is fine. Possible that the wheel bore itself doesn't have enough diameter to clear the Brembo brakes. Not a measurement provided above.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Yup they work, even with the brembos.
5pointOh
Jax, FL
I found this online: Hub Bore: 70.6
kz
West Chester, OH
Mustangs & F150
That isn't what you should be looking for. Look at your current wheels - inside diameter of a rim is what determines whether they fit over larger brakes. None of measurements above says anything about it. It also unfortunately isn't a measurement manufacturers provide. Is it OE Wheels ?
5pointOh
Jax, FL
Yes its OE Wheels
