Will I need camber plates or bolts?
Canti
Atlanta
2018 GT Premium
TJ, do you have a forum code that I could use? I had pretty much decided to with the Steeda camber plates, roll center & bumpsteer correction kit, and rear billet rear shock mount.
Bear380spin
Monterey
Jonathan
2021 5.0 manual
Hello I am getting a setup of sve r357 with eibach red sport lowering springs (1.5 drop). Should I get camber bolts or camber plates? It would be a huge help.
Front 19 x 10 285/35r/19. +35mm offset
Rear 19 x 11 305/35r/19. +50mm offset
NightmareMoon
2016 Mustang GT PP w/ Voodoo
What are your goals or concerns?
Bear380spin
Monterey
Jonathan
2021 5.0 manual
My goal is to be lowered a bit and my concern is that I won’t be in proper alignment. Will camber bolts be enough to get me back in proper alignment but I am thinking of getting camber plates to be safe.
tj@steeda
Timothy
Jonathan,
Not blowing smoke but if you have the budget ... it is best to compliment the springs with the camber plates. If the bolts don't work ... you will be back at square one.
We put the camber plates on 99% of the cars we lower here at Steeda - peace of mind that you will get it in spec & save on tires down the road.
Keep an eye out - historically, we have always had a 4th of July Sale ... there may be some savings coming up.
TJ
