Whose gonna be the test mule???
  • Thread starter Deleted member
  • Start date
  • Watchers 7
Blue Moon
Maine, or eastern Canada
Pete
17 Ecoboost Perform Pack Std
I like the noise I get with my DV+ and Cobb CAI. More noise than that would probably be too much for my liking.
CanadianStang
Québec, Canada
Philippe
FORD MUSTANG ECOBOOST 2015 AT NO PP.
Its just the same as having a boomba blowoff on top of your db+ , but better quality since it’s just one piece .
Sounds the same as any other vent-to-atmosphere bypass
I may order one
Im currently using a rub chair on my intake tube for the blow off sound . I heard it was as loud as any other bypass ; is it true ?
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
Question. What is the performance function of a blow off valve?
Deleted member
Guest
Stock our cars come with an electronically controlled Diverter valve not a BOV. BOV's are usually vacuum operated, but they both do the same thing. The problem with the stock unit, is the plunger/spring that keep it closed are pretty weak stock and it is a weak point for a boost leak at higher PSI's. So you're not gaining HP with an aftermarket one, as much as you are making sure that you don't have any boost leaks when you start making more power. Go Fast Bits make a insert (the DV+) that replaces the stock plunger/spring that is inside the stock DV, thus preventing boost leaks while maintaining the stock electronic operation.
Vicr
Vic
So my next question is there an after market DV that doesn't deliberately make "the noise". I would like to upgrade the DV but not have the noise if I don't have too.
Deleted member
Guest
Yes you get a DV+ from Go fast bits and just keep the hose attached to the stock diverted valve that recirculates to the intake. That way you get the added benefit of the DV+ with no noise.
RichBrew
GA
Scott
2019 Velocity Blue EBPP
Blow off valve/bypass valve (aka BOV/BPV) holds pressure in the intake system when under boost, but releases it when not needed to prevent damage to the turbo. There are two primary styles, one that vents to atmosphere, and one that vents to a re-circulation tube. Generally a BOV is VTA, and a BPV is recirc. BOV will make noise when it vents, BPV is quiet since it vents back into the intake. Either style can be controlled either by the ECU or by vacuum.
