Whiteline KDT933 Diff Bushings Discontinued
blind*guardian
Reseda, CA
2019 Mustang GT
I disagree. I hear my diff gears whine all the time. Does it bother me? Now that I know nothing is broken/breaking, no. But I wouldn't qualify it as zero.
On a scale of 0 (no added noise) to 10 (I can't hear my radio on full blast), I'd rate them a 3. Its noticeable at low speed only but minor when you do notice it.
The NVH can vary depending on a particular setup as well. If you have 3.73 gears, that for example, can result in more NVH than 3.55. Auto vs manual, as well as any other mods/differences, can result in different NVH. Perhaps mine aren’t a 0 NVH increase, but not a 3 either. It’s really barely noticeable for me.
shogun32
Northern VA
Do you know what stiffness the Whiteline inserts are?
85A durometer.
I've been in 2 cars with 'red' pucks and the diff 'sings/howls' at sympathetic frequencies. If I turn my radio way down <5 I can hear mine steady in the background.
shogun32
Northern VA
@shogun32 do you have Whiteline in your diff? (It isn't completely clear in your post.)
Yes KDT933 in both Mustangs. (one since sold, it's in NJ someplace I reckon. Look for a N4G EB with GT/PP1 wheels)
Performance nut
TX
2018 Mustang GT A10
Not sure why gear ratios would affect NVH. Engagement is engagement as far as gears go as far as I know. The transmission... not how that would affect the differential bushings transmitting more noise from the differential.
I do know that the Torsen is way louder than the 3.15 differential (true-loc or whatever its called). Same exact setup, two different differentials. Old diff was a zero, this one is a 3. Yes gear ratios were also different but I have doubts gear ratio matters. If they made a 3.15 Torsen, i would think it would be just as loud.
Brazos609
2015 GT Premium PP Recaro
moffetts
San Mateo CA
Black Whippled 2015 GT PP
They don't, it's just that the only 3.73 (and only Torsen) from the factory is a 3.73 Torsen. That's why the two terms are used interchangeably unless stated otherwise.
shogun32
Northern VA
pretty sure the 3.55 for the EB/PP manual was a Torsen
moffetts
San Mateo CA
Oh, well then I guess being specific about LSD type and gear ratio is much more important, then!
