WHIPPLE 3.50" Pulley
thedalejrfan
Toronto
Bob
2019 BULLITT K3985
Hey guys, is anyone here running the Whipple 3.50"pulley on the 2015?
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
I am, just haven't had time to dyno or go to the track. My car pulls a lot harder now than when I had the 3.75 pulley.
thedalejrfan
thedalejrfan
Toronto
Bob
2019 BULLITT K3985
Be careful!!! I installed the pulley and new tune from Whipple yesterday, put it on the dyno and I am running dangerously mean at high rpm. I data logged and sent the results to Whipple. According to Whipple, we are out of fuel system at this level!!!
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
You are probably running a higher boost than I am. I see that you have the larger TB. I still have the stock TB. Do you have a boost a pump?
thedalejrfan
thedalejrfan
Toronto
Bob
2019 BULLITT K3985
I have the larger throttle body and BAP
LethalPerformance
Fl
2020 Shelby GT500 CFTP, 2021 Whipple'd F150
We're currently running a 15% OD balancer and a 3.875" upper pulley. I believe that combo yields us 15psi. We will be putting on a smaller pulley today to yield us 18-19psi.
We'll let you know the results once the car is tuned.
Jared
Whipple SC
Fresno
Just so it's clear on "out of fuel". It's because fuel psi is falling, which makes the fuel inj have to open more to compensate. If it can hold 58psi, it would have no problem flowing enough fuel.
thedalejrfan
thedalejrfan
Toronto
Bob
2019 BULLITT K3985
Correct, we have another car with the same setup and stock 3.75"pulley that we are going to run on the dyno today for comparison. I will post results
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
Was the 705hp with the 3.50 pulley?
jayman33
Fort Bragg, NC
Jason
24 GT
One of our customers was running the 3.5 with our Fore fuel system, he made right around 835ish on E85. No detonation either:)
bmoore1488
whodafuk
SD
Brandon
2015 Black GT 6MT
What did you make on the 3.50?
thedalejrfan
thedalejrfan
Toronto
Bob
2019 BULLITT K3985
Didn't get to make a full pull, running way too lean. It was making a ton of power up until we aborted the run. Waiting for the LTH tune...
