Whipple installation - Suggestions-
v8ter
v8ter
Typing...
EL PASO , TX
MUSTANG GT 2015 50TH
So the manual calls for a 36101 pulley but theyre all marked with the same number but they have a different bearing though, can somone help me whats what?
sigintel
Ray
2018 GT
Nope. Lol.
Got a pair of dial calipers or digital calipers?
$10 harbor frright.
Ruler in mm and inches works ok.
Instructions give bolt specs. Aleays consider there MIGHT be a typo so stay chill.
Start matching up bolts and just dry fit it all together. If you are wrong you just pull apart and redo. Advantage of trying is becoming familiar with parts and the nuanced differences start to just jump out at you.
Some bearing IDs might be smaller than others.
If you have ipad or ipown you can save install pdf to ibooks and zoom in images. Hella useful.
v8ter
v8ter
Typing...
EL PASO , TX
Theyre all the same in bearing diameter, but some seem to have thicker bearings but I got a confirmation that theyre all the same
v8ter
v8ter
Typing...
EL PASO , TX
So what connects to the rear imrc connectors? Ive read the instruction and its not clear if I should just leave them unplugged ? I have 2 remaining?
v8ter
v8ter
Typing...
EL PASO , TX
Ingot2015
CT
Ron
2015 gt
Thats right. You only use two.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Make sure you plug the I/C Pump harness into the shorter of the 2 blue in color IMRC connector it has the yellow/grey and green wires. The other blue one is left to be tapped out of the way. The other IAT harnes plugs into the white IMR connector one closer to the pass side, and again the other is taped back out of the way.
v8ter
v8ter
Typing...
EL PASO , TX
Awsome!! Thanks, you guys rock!!!
v8ter
v8ter
Typing...
EL PASO , TX
Does somone have a picture of the intercooler from close up? It says I need 2 8mm x 25mm bolts but theres only one =(
v8ter
v8ter
Typing...
EL PASO , TX
sigintel
Ray
2018 GT
Looking good!!!
The motor moves/rocks on the mounts, so dont tightly ziptie any motor harness to anything hard mounted to the firewall. This just leads to serious cyclic wrenching on the harness.
Better yet, make a little L or Z strip of aluminum (hardware store) to support the harness using the bolts on back of SC.
And clean that dirt and dust out first next time before disconnecting electrical connections or removing an intake. You dont want a cat turd or rusty tonka trunk to get in your way or foul anything up. ;)
I was short one bolt for the tank to go thru chassis tube so I borrowed one from futton frame until I picked one up from hardware store. Whipple will send you anything short so once you are 1000% done and have a final missing parts list they can send you whatever. Dont let one minor part hokd you up. Just note in manual and keep truckn. Might find it later or snag what you need off old intake or some busty ass futon on back deck...
v8ter
v8ter
Typing...
EL PASO , TX
Thanks for helping me out, will do that!!!
