Whipple Competition Kit Install Questions
Project Whitemare
GTFO Squad
Bay Area
www.instagram.com
Nick
2015 Mustang GT/PP
Hello gentlemen, I'm in the process of installing my Whipple and have a question about the IMRC connectors and the Intercooler harness.
My understanding is that the Complete kits use the IMRC connectors at the back of the passenger side of the block.
I want to verify that the Competition kits have a different harness that does not untilIze any of the IMRC connectors, but instead is using a fuse tap.
Can somebody confirm or correct me.
jayman33
Fort Bragg, NC
Jason
24 GT
You check your fans?
Project Whitemare
Project Whitemare
GTFO Squad
Bay Area
www.instagram.com
Nick
2015 Mustang GT/PP
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Nick, I just responded on the other thread you posted in. Let me know if I can help further :thumbsup:
Bkingnorth
Western NY
2016 mustang gt
Correct. Also note that if anyone wants to use the imrc connections to power the relay for the innercooler pump, you must use the whipple tune which has programming to utilize that circuit. I haven't been able to configure that myself using Lund or hp tuners.
NOTE: there are spots to fuse tap but be aware there is a known issue with battery's dying from the relay sticking and the pump running.
Zobot
Pittsburgh
2015 C.O. Mustang GT
Hey, did you get your answer? That looks like an older harness. Contact whipple and they'll send you the correct one. I had the same problem
Project Whitemare
Project Whitemare
GTFO Squad
Bay Area
www.instagram.com
Nick
2015 Mustang GT/PP
So here's what ultimately happened.
I received the harness shown in the pictures above for the Intercooler Pump Harness. As you can see they are a bit different from the one included in the Complete Kit (as seen on the diagram).
Not only does the Intercooler Pump Harness not connect to the IMRC circuit, but it also does not have the "turn on for dual fan relay" orange wire with connector attached. Instead it had an orange wire with a fuse tap attached. The (4) IMRC connectors at the back of the block all get taped up.
The Dual Fan Harness I received was exactly as pictured in the diagram with the exception of only one ground as opposed to two.
So here is the dilemma. I have nothing to plug into the connector on the dual fan harness, because I don't have a "turn on for dual fan relay" connector on an orange wire on the Intercooler Harness to connect to. I assumed the fuse tap coming off the orange wire was in lieu of this connector and moved forward and completed the install. Turns out the fans wouldn't turn on. I tested the connector with a jumper wire, and the fans turned on.
I can solve this by just cutting off the connector and tapping into a switched source, but I want this done the right way. I'm not sure if I received the wrong harness, but as of now I don't want to cut off this connector if I will be needing a different harness to connect to.
Anyone with a Competition kit (non Whipple-tuned kit) I would appreciate your feedback.
My instruction manual is the update as of 10/26/16.
Greatlifejohn
2017 ford mustang gt 2.9 whipple stage 2 longtubes
Hey sorry I know I’m like 8 years late but I bought a used kit and it came with only the wire for the dual fan not the pump harness… Or did Whipple upgrade the harness? Did that harness get the pump to work I don’t have fans on my intercooler so I don’t really need that harness for the fan.. If it does power up the pump to run what errors did you experience later on if any… Did you catch any codes since nothing is connected to the imr.. Just curious.. Thank you
