Whipple charged voodoo upgrades required?
Jdown
NY
JOSH
2019 gt350 whipple charged, 1972 Camaro SS pro touring
Hey all I have a 19 gt350 with a Whipple on it since basic birth. Been a flawless setup till the other day with 15000mis. Seems to have a issue with 1 cylinder showing oil on a plug and a knock. Was wondering if anyone knows what's needed to help bulletproof the voodoo for boost as I really enjoy this Power plant. If I have to remove it id like to beef it up to get some more longevity. Any input would be appreciated
Jdown
Jdown
NY
JOSH
beefcake
Bethel
2018 Ford Mustang
Do you plan on making more power in the future? Building the bottom end is one option can leave the top end stock. Id run a catch can setup if you arent already
LethalSteveG
South Florida
2018 Saleen Yellow Label
With saying there is a knock, the motor might need to be looked at. If that is the case, a piston, rod, OPG and sprocket is pretty much all you need if you want it to handle more boost. You can swap for head studs and things like that if you plan on seeing tons of higher RPM too but that is more so on your goals with the car. From there it's fueling, catch cans, and more.
I would start off with having it looked at. Maybe a leak down and compression test to see what is going on than address from there.
If you do decide to build the motor and get anything supporting, let us know if we can help as we offer tons of parts for these.
https://www.lethalperformance.com/s...-gt350r/2015-2017-2018-2019-shelby-gt350-ford
Jdown
Jdown
NY
JOSH
Thank you i haven't had the time to dig deep into yet but did a static compression test and showed no difference going to do a leak down next and pull valve cover off to see if anything looks off plus going to drop oil and cut filter to see if any metal is showing
Mach1Racer
Everywhere
Mach 1
What cans do you suggest? Both sides?
Jdown
Jdown
NY
JOSH
beefcake
Bethel
2018 Ford Mustang
