moffetts
- Nov 30, 2015
- San Mateo CA
- Black Whippled 2015 GT PP
I drove my car last night and I noticed that I was not getting much whine, especially at low throttle (and I have the sound tube mod so normally it is quite loud at WOT and I get a little bit of a whistle at low throttle) and the car is definitely down on power. I am seeing about 2 degrees of timing advance at WOT which is normal, so I don’t think there’s a fuel issue. I am wondering if I have a stuck bypass valve, since that is a relatively common issue that can cause these symptoms. I did recently do the stage 1 > 2 upgrades but the car ran like a scalded rat up until recently, so I don’t think there’s an issue with the install (or the o ring on the bottom of the blower where it meets the manifold, more specifically).
As far as the bypass valve is concerned, I would like to test it before I take the blower off (again) and risk that not being the issue. Is hooking a vacuum pump up to the vacuum hose going into the bypass valve the best way to test it?
