What happened to my MT82? Issues & help requested
geep81
Cleveland OH
2020 GT Premium
Today at lunch took the car, 0 issues whatsoever.
Today going home, car did not want to shift into 1st.
Shifts between 1-2 and 1-2-3 are very tough most of the time. Sometimes "normal".
Downshifting from 4th to 3rd seemed easier. But 1-2 and into 3 was like pushing thru rocks often.
Do not see any signs of leaks under the car.
Have a MGW shifter installed this spring, have had no issues with since installed.
Shifter feels normal when car is off, can cycle through the gears easily.
I do notice that as I am in neutral going to first, revving the engine up before engaging I seem to feel more "wobble" than normal.
Rwwilli09
Olathe, KS
Rusty
2016 Mustang GT, 2021 GT Convertible, 2020Edge ST
How many miles? Stock clutch?
geep81
geep81
Cleveland OH
2020 GT Premium
41k miles, stock clutch
NGOT8R
Adrian
2019 Bullitt
Has your fluid ever been changed? If not, I’d try bleeding/flushing the entire brake/clutch system until the fluid is clear and then test to see how it feels.
NGOT8R
Adrian
2019 Bullitt
If the fluid bleeding/flush doesn’t work, you may need to pull the tranny, open it up and inspect to determine condition of the reverse shift fork pads. I’ve read at least one thread where someone’s broke apart and led to other issues in their tranny.
FYI, this is about the least invasive option, as they can be easily replaced and upgraded with bronze pads. All that is required is to remove the tranny output flange and tail cover and use a heat gun to get the pads hot (melting) and simply pull them out and replace them with the bronze pads.
https://www.allstategear.com/MT82-6...yu3xLgal1xjO6zzY5jcZzYwNesIlVmvqLp8xjKf8OJhQY
Rwwilli09
Olathe, KS
Rusty
^^^ This is my guess as well.
SHOdaddy68
Washington State
Daryl
2015 GT PP Premium w/Recaro
The clutch is not fully disengaging because the TOB is not completely actuating the PP springs. Could also be a PP failure.
geep81
geep81
Cleveland OH
2020 GT Premium
Very cool post NGOT8R, thanks very cool.
The fluid was changed with BG synchro 2 about a year ago now.
I do beat on the car, not insane, but I've never been scared to slam it around when I want to have some fun.
Car is at a really great Mustang specialty shop now, the best place around I could take it imo, they are going to investigate before we buy any parts, I should know a diagnosis this weekend.
1-2-3 were very hard to go into, 3-4 not as much, and 5-6 were better than the rest. Going from 4-3 it felt pretty normal. From a stop, releasing the clutch to feather it a bit and get it going there's a LOT of chatter and shaking until it engages.
