What fuse taps to use?
psylocibin
US
2016 Ecoboost
I'm wondering what fuse taps I should be using for the interior footwell fuse box or if anyone has used them yet? I wired some interior accent lighting today and the 3 supplied taps (standard, mini, low profile) don't fit, so I had to use the cigarette lighter for now. I'd prefer a clean installation, but the fuses seem to use some weird 3 prong design or a Mico fuse of sorts (fuses small enough to fit in to 1 side of a standard fuse connector).
Thanks for any help.
wizdumb
Jay
2016 Mustang Turbo
No problem:cheers:
Lime1GT
Winnipeg, Mb. Ca.
Thomas
2017 Mustang GT PP
Some fuse panels I've installed Add-a-Fuse to I've modified the fuse cover with a solder gun smoothing blade, to channel the wire and make extra room.
louierg
Louisiana
Louie
2015 50th Anniversary Limited Edition #1897
Reading the comments on Amazon.. It does NOT fit 2017 Mustang without modification. can anyone confirm this?
I have not looked at the panel to see how much room there is in height to the cover. Wonder if I should make a plate like tap I have seen in pics to lie flush with the cover.
jordystang69
NY
2017 Mustang GT Lightning Blue
This is correct. I had to take a metal file and shave away a bunch of plastic. Would not recommend getting this brand.
louierg
Louisiana
Louie
Purchased a tap from NAPA. Fits well. Very expensive. Ordered one from Oreiley. Will be picking it up. Half the cost.
catchthecarp
STL MO
2017 White Platinum Premium GT
I can confirm that the Lumision fuse taps sold by Amazon do not work, they will not seat all the way in the fuse slot. I returned them.
See this post.
