What does a used D1SC go for?
Chummel
Tulsa, Ok
2015 Mustang GT PP
Like the title states.. what does a used D1SC head unit sale for? I'm considering the D1X upgrade but at $1,700 it almost seems better to sell the D1SC and get an F1A94.
Chummel
Chummel
Tulsa, Ok
2015 Mustang GT PP
What is the goal here?
Well i think i have the wife on board with getting a sleeved RPG long block, so when that happens the goal is big power
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Id recommend getting the engine first and maxing out the D1sc, then upgrading the blower.
You can expect to sell the d1sc for probably 1500.
Chummel
Chummel
Tulsa, Ok
2015 Mustang GT PP
Thats the plan, just trying to think ahead. The only other mod (I think) that needs to be upgraded to handle big power is injectors. I'm around 800 whp right now and after being boosted since 2015 it doesnt feel like enough. Granted my gears are crazy long so i am sure a jump to 4.10 or 4.56 would make it feel faster.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
It wouldn't just feel faster, it would be quicker/faster with the gear swap. Adding power is what most do, because it takes the least effort. Optimization is where its at, make the most of what you have.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
You mentioned big power. Whats the plan for that power? Drag, street race, road race, hard parking?
fuelforfire87
IL
2014 Shelby GT500
Maxing out the D1SC should get you to into the low to mid 900 whp range. I currently have my D1SC on a 4.0 pulley which puts me at max impeller RPM shifting at 7500. Am going back to the dyno on the 27th so will have updated dyno numbers then.
fuelforfire87
IL
2014 Shelby GT500
Yea you will definitely need to upgrade injectors to ID1300x's and get a proper return fuel system like a Fore dual or triple pump setup for supporting more power, especially if you get a F series blower.
Chummel
Chummel
Tulsa, Ok
2015 Mustang GT PP
Fun cruising around. I don't race currently, not a hard parker either. I just enjoy driving and going fast.
Chummel
Chummel
Tulsa, Ok
2015 Mustang GT PP
I have a triple pump set up currently. I have talked to Beefcake about the 1300x's and that is what i will get when its time.
Chummel
Chummel
Tulsa, Ok
2015 Mustang GT PP
Let me know! are you on stock block? I want to turn it up more (im on a 4.5" pulley) but don't want to hurt the motor.
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
I agree with 80foxcoupe. But it is so fun to say F1a94 and Procharge all the things.
FastCarFanBoy
2013 GB GT
Standard diameter crank pulley? You should only be at just under 59k rpm with the 4.0" , D1SC recommended max rpm is 62k
fuelforfire87
IL
2014 Shelby GT500
Built motor with MMR 1000 Short Block L&M intake cams and Boss heads. I would stay with that pulley size on the stock motor. That's actually the same pulley size I was running when I had my stock gen 1 motor.
According to the Procharger blower RPM calculator, With the stage 2 8" crank pulley and 4" supercharger pulley shifting at 7500 rpm gives you 61500 blower rpm.
https://www.procharger.com/calculators
