VTT drop in LPFP upgrade announcement!
Slow89
Some place out west
11 sec bolt on ecoboost // 9.2 @ 151 2019 blower GTCS
So just to clarify I can run 100% e85 on stock injectors with this pump? If yes what HP range do you see this maxing out a stock turbo with no other fuel mod besides this.
VargasTurboTech
VargasTurboTech
Hayward, CA
Turbo everything
So just to clarify I can run 100% e85 on stock injectors with this pimp? If yes what HP range do you see this maxing out a stock turbo with no other fuel mod besides this.
You can run any fuel you want on this pump, you can run any injectors you want. This pump is simply a higher flowing pump that feeds the HPFP system, which is the HPFP, and DI injectors. If you have an Aux system it fuels that as well. If you are on E85 at nearing 350WHP your stock pump is getting to the point where it can't keep up, and should be replaced. If you just wanted to upgrade for future power. This pump can be installed in a dead stock car pulled off the showroom floor, and would work perfectly.
apx632
The Woodlands, TX
2016 Ecoboost Mustang Stock- 13.64@100 1/4 mile
None of this is cost effective. I have AUX fuel now, and am planning on buying a HPFP as well when they become available. I just ordered this LPFP this evening as ive been on borrowed time not having it. I like that it just drops right in, anything that appears stock is my cup of tea. I think that the LPFP is one of the most important ingredients to getting the fuel system to work properly. Its true job is to get enough fuel from the center of the car to the HPFP in the front of the car, and if using AUX fuel, its gotta feed both, so its got a lot of volume to move, it needs to be upgraded if your using E85, or heck even if your on E30 and have the wick turned way up I bet.
By drop in do you mean dropping the fuel tank and putting it in? I've not actually looked up the LPFP's on these cars yet.
Juben
Chattanooga, TN
Justin
2015 EcoBoost Mustang (AT) w/PP
You pop out the lower portion of the rear seat. It's located under it. Easy peasy.
5.0yote
AKA Bananana & 3.7Cyclone
Mansfield, MA
www.youtube.com
Don
2016 Mustang Ecoboost Premium
Yeah this is a 10 minute swap at the most, unless you cannot find the tabs to push to remove the seat bottom =)
