Vortech BAP install help?
ColtonimusPrime
Savannah, GA
Chip
2016 GT PP
Did anybody ever do a write up on how to wire the vortech bap? I'm installing mine tomorrow and would like to have some clue of what I'm doing, lol.
Tugger50H
STL
Tony
2015 GT
Its pretty simple just did it last week so its fairly fresh and my mind. Remove the backseat, you will feel two large push tabs one on each side and the seat lifts up and out. Driver side disconnect the plug from the relay and remove the loom and tape enough to give yourself room to work. Cut the purple and green wire. The red wire with the fuse goes on the harness side and the orange wire goes to the plug side. Ground the black wire to body and coil up the brown wire out of the way as its not used. Solder your connections and mount the bap.
http://www.vortechsuperchargers.com/images/64.pdf
beefcake
Bethel
2018 Ford Mustang
there ya go!!!
ColtonimusPrime
ColtonimusPrime
Savannah, GA
Chip
2016 GT PP
Awesome thanks! One more thing, I remember reading somewhere to make sure your fuel pump fuse is a 30 not a 15. We're taking about number 49 under the hood right?
Tugger50H
STL
Tony
2015 GT
I didn't change any fuses under the hood just checked to make sure the 40amp was in BAP fuse holder.
ColtonimusPrime
ColtonimusPrime
Savannah, GA
Chip
2016 GT PP
Hey thanks for the help guys! Got it installed along with the rest of the PC and everything seems to be running fine so far.
Tugger50H
STL
Tony
2015 GT
Glad to hear it
