sigintel
- Nov 24, 2015
- Republic of Texas, God's Country
- Ray
- 2018 GT
Still have?Start out with the simple stuff.
1. Tires have a March 2017 date code on them
2. This was there second track day, approximately 8, 20 minute sessions, two in the rain
3. They had been to work maybe 3 times and 2 cars and coffees. I would say maybe 60 road miles
4. 38 psi at the beginning of this session, when it is cold I run 34 psi
As for Alignment
1. 2.3 degrees negative camber D and 2.1 degrees P
2. 6.4 caster and 6.1 caster respectively
3. I run a 1/16th toed in
I have the rear alignment specs and scale weights, but not sure they are relevant. During the rebuild I am working at moving weight to the center of the car, to make it less polar. Also my passenger side rear tire is light, so I am going to out the battery over it. Neither here nor there. The failure was completely unexpected, and for reference the wheel structurally lived. Now could it have handled heat and flexing better? I am hoping so on my replacements and I have added lots of brake cooling.
Did the intact inner sidewall have a greasy graphite feel to it?
Any blisters on inner sidewall?
Bead steel seperate from bead gum?
Could we see wire with thin layer of rubber covering bead wire core?
You can get an idea of how fast the tire went down
