Upshift AFR Querrey
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
If you guys with 15-17 MT82 GT could check if your AFR goes to 20:1 on a up shift that would be great. Thanks.
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
It's not supposed to.
W.O.T. Stang
Jim
2019 Mustang GT Premium PP1 401A
Are you confusing upshift with downshift? When you go from 3rd to 2nd and coast - you are going to see see 20:1 - as the engine goes lean as the injectors shut off, and sees full vacuum with the throttle plate closed.
IF you are seeing it on acceleration - which i cant see how - you have many other issues and would most likely be seeing drivability issues and a check engine light at minimum.
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
No not confusing upshift/downshift
upshift: 2nd to 3rd gear
downshift: 3rd to 2nd gear
The upshifts goto 20:1 for a instant, then normalize. Downshifts does the normal downshift crap.
Cory S
Bradford, NH
Cory
Are we talking super slow granny shifting?
Cory S
Bradford, NH
Cory
WildHorse
WildHorse
N/A or GO HOME
Puddintane
'17 S550
Does it do it above or below a certain speed?
Just when I normally shift. 15 kph 30 kph 45 kph 60 kph those points ate between 2k to 3k rpm
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
It's your DFCO settings.
Mghoward74
San Diego
Greg
S550
Decel fuel cutoff. It’s used to save gas/fuel
any time you coast (not in gear, AFR/lambda) will show lean conditions
K4fxd
NKY
