Tvs 2300 issues
Snakebyte69
Chicago,il
2016 gt
The day I ran 11.8 @121 the da was 300. I have a 305/35/19 nt05r. 1.89 60 foot. The problem also is shifting into fifth is so unnatural and time consuming. The cover was on.
JasinEdward
Spring Hill
Jason
2015 5.0 Roush Stage 1
I just got my 16GT with the TVS/Roush about a week ago. I put around 100 miles on it and man that tune is HORRIBLE. I went ahead and had Lund send me a tune. It is a different animal now. I went to the track yesterday. My car is a automatic. It pulled a 1.64 60' but spun when it shifted to 2nd so I had to get out of it and back in it. It went a 10.95@125. That is all stock besides the TVS
Wow! What tires are you running? And is this on the Roush injectors?
NicksRubyRed15GT
Chapel Hill NC
Nick
Deep impact blue 16 GT
I was running 295/45/17 Mickey Thompson drag radials. It has the injectors in it that came with the kit which are 47lb inj also
Guard5.0
Indiana
2021 Rapid Red GT500 CFTP
The initial 627 tune was bad. Would go into limp mode if pushed at all and sluggish all around. I think the 670 tune was intended to fix all of that but I didn't like it either (probably why it was free). Still sluggish on throttle response, idle inconsistencies, flattened out at higher RPM's. Phase 2 should have probably been phase 1 (likely warranty issues). Throttle response is much improved, solid power curve, good idle. If you go phase 2, remove the lid from the airbox you should see 630-640rwhp on a Dynojet and your butt dyno will tell you that the car is now running like it should. I know some guys are in the high 10's with the 670 tune but I'm sure it takes a very clean run to get that.
It's all according to what you want. If you want 700rwhp you'll have to go custom w/ injectors and BAP or wait around for phase 3 which I'm sure will require new injectors but should tickle the 700 mark.
