Tuning complete. Time for the track!
Jay-rod427
Kansas
2016 GT C/S
Finally got everything lined out and ready to rip the track tomorrow night and see what does or doesn't break. LOL. Hopefully all goes smooth and as expected and not picking up halfshaft pieces.
Jon Jr at Lund has done the tuning as I specifically requested him. Had to work through a little bit of false knock issue, Jon attributed it to blower noise/vibe being picked up since it was very intermittent and lowered the knock sensor sensitivity slightly. Works great now and knock sensors still very active.
Here is the latest street datalog. A bit of tire spin rolling into 2nd, and every shift thereafter. Traction control pulling timing down for a bit, and then limiting top end timing. Rolling into 3rd it throws full 22 or so degrees at it when traction control doesn't intervene. Got one more revision from this to get the 2-3 shift a little sooner. 8,000 and 16 lbs is a little much. LOL. Will have 1-2 data hopefully from the track.
https://datazap.me/u/jay-rod427/final-revision?log=0&data=1
Build details.
P1X stg 2 w/4.50" blower pulley, 13-14lbs at 7500-7600.
Fore L4 triple pump w/FC3 on hobbs switch
ID1050X's
E85
2018 Manifold locked out
Circle D 4c
MT ET street SS 305/45/17
All stock otherwise.
Jay-rod427
Jay-rod427
Kansas
2016 GT C/S
That's exciting!
You have no idea how excited I am to give it a rip from a dig. Slow rolling into second is getting old! This should end up being the fastest car I've ever driven. Hoping to get into the 9's a bit.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
How much whp are you guessing? What et/mph u shooting for?
Jay-rod427
Jay-rod427
Kansas
2016 GT C/S
Dunno 750-800 maybe.?.?. Man if it went out and went 9.80 @137-140 I'd be pumped. Tuning is pretty soft on the shifts to minimize breaking/spinning, and could up the shifts if need a little more power,but 14 lbs was my comfort zone. But realistically however/if it runs into the 9's I will slow it down to 10.0
gimmie11s
SoCal
Murica!
My feelings exactly about my car. It's the fastest thing ive ever owned and seriously dangerous on the street going WOT. Keep her on the track lol.
Good times for you ahead, im sure. Congrats.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
If it makes 800whp, it should trap 146ish. I'm going 141 on 700whp. Et will depend on prep, trans shift points etc.
Jay-rod427
Jay-rod427
Kansas
2016 GT C/S
Gotcha. Like I said no idea nor do I care about whp. How hard are you turning yours on pump gas? I can't remember have you done any suspension work?
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I see 17 degrees on pump. I've found if the 6r80 shift points are conservative, car will slow down a bunch. Also my car 60fts quicker just going wide open from idle. Throttling up to say 2800 on the footbrake then going wide open slows the car down. Bmr080, proactions, vertical links, adj to links and cradle lockout is what I got.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
Just saying since u are street tuned, the mph will give u an idea of whp.
Jay-rod427
Jay-rod427
Kansas
2016 GT C/S
Get that 2-step going and I bet 60' picks up a few numbers. No delay on the electronic throttle.
I honestly don't know if I'll get off the line worth a shit with zero suspension work done.... next on the wants list.
Jay-rod427
Jay-rod427
Kansas
2016 GT C/S
For sure. The shifts have torque reduction applied, but shifting at 7500 should make some decent steam. Hopefully E85 and more timing should yield half decent mph. Anything under 10.00 is a win for me as I don't want to cage it and all that crap yet. Low 1.50's 60', but run decent mph out the back would be ideal for me.
Jay-rod427
Jay-rod427
Kansas
2016 GT C/S
If you buy into MAF to hp approximation it maxes out at 7,200 rpm so figure 17% drivetrain loss 715 whp give or take. So 750 might be close. I'll prob dyno it at some point for kicks to correlate a datalog with output.
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
I def want to see if there is benefits to the 2step without transbrake. Hopefully there is!
BadGTR
Belen, NM
15 GT Auto, 1400HP GTR
Are you not turning the traction control completely off? I would think completely disabling it would not pull timing, even with traction loss? I would think your making 800rwhp easily.
