I would say the main issue with 20" wheels is that those 20" wheels move the weight of the rim a full 1" out from the center of the hub over an 18" wheel. This has a profound impact on acceleration and braking capabilities of the car as well as the consumables used in those applications (ie: Brake Pads and Rotors and gas).The main issue will 20 inch wheels and lower profile tires is decreased ride comfort.
Yep, rotational inertia.I would say the main issue with 20" wheels is that those 20" wheels move the weight of the rim a full 1" out from the center of the hub over an 18" wheel. This has a profound impact on acceleration and braking capabilities of the car as well as the consumables used in those applications (ie: Brake Pads and Rotors and gas).
Decreased ride comfort pales in comparison to the effects of 20" wheels on braking and acceleration...
SVT prototype has already been spotted with 295's up front and the S197 could swallow 315's up front with the right wheels and some negative camber and a shorter overall tire height (less than 26.7").Yep, rotational inertia.
Again I'm okay with the 19's if it gives us and advantage in acceleration and braking. I may like to upgrade to a wider offset wheel/tire package someday as well. Maybe a 275 front 295 rear stagger. If they will fit without rubbing. We will have to see what type of room is under those wheel wells.
I hope you're right. I'd love to put some really fat rubber under both ends. ;)SVT prototype has already been spotted with 295's up front and the S197 could swallow 315's up front with the right wheels and some negative camber and a shorter overall tire height (less than 26.7").
I'm just glad the 14" Brembo option will fit 18" wheels... I don't want 19" wheels or 20" wheels just based on the cost of the tires alone.
Also, the S197 could swallow some pretty wide tires out back too and since this car has a wider track and fenders to match, I would be shocked if you couldn't fit at least 315's out back without rubbing. Supposedly the SVT car is going to have 11" wide front wheels and 13" wide rear wheels... 295's up front and something substantially larger out back like 315's or 335's. For handling I would fight for a square tire setup though to help ward off understeer.
Having gone from 18 inch stock to 20x9 on my 2011 and from 17 inch stock to 20's on my '06 and '07 the only noticeable differences were improved cornering/turn in and harsher ride, the "profound impact on acceleration and braking" you speak of........nope, noticed no difference gas mileage, brake pad wear or in acceleration, other than slightly better hookup on hard take off which could be due to the type of tires. If it does decrease acceleration it's such a small amount you aren't going to notice unless you are at a track and counting the tenths of seconds, and most people aren't.I would say the main issue with 20" wheels is that those 20" wheels move the weight of the rim a full 1" out from the center of the hub over an 18" wheel. This has a profound impact on acceleration and braking capabilities of the car as well as the consumables used in those applications (ie: Brake Pads and Rotors and gas).
