Traction Control
ralph7
Houston
2000 GMC Sierra 1500, 2019 Mustang Bullitt
If launching hard on a hard surface, will both tires not spin if the traction control is turned off?
Ls_Eater
Apollo Beach
Parker
2018 Magnetic Metallic GT
If TC is not fully disabled - no - they won't spin it will just bog down until TC senses it's fine and ramps back in the power.
Turning TC completely off by holding the button for 10~ seconds, will enable you to do a burnout.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Mine will do a burnout with TC on, just not very far.
Turning TC off and leaving advance track on, will allow a burnout and not let you spin out. Turning it all off gets you a YT video
Snellemin
Houston
Bullitt
So far for me, turning it all off doesn't give me the YT vid scenario. Instead the rear breaks loose from 1st to 2nd and I can correct it. With just the TC off, the car still tries to overcorrect itself and the YT vid scenario pops up.
Golgo69
Herb
2019 BULLITT
does it go back to normal after the car is turned off and on (holding the button down for 10 seconds). Also, (for anyone to answer) are the YT videos a result of the traction control being on? And if you do the "10 second", hold will this prevent the YT plowing into people?
Ls_Eater
Apollo Beach
Parker
Yes, it resets with every key cycle.
Crashes are the result of incompetent drivers 99% of the time - the assumption that traction control will or will not save you is a portion of that.
Know your own driving limits, the limits of your car, and the limits of the environment you’re in.
Golgo69
Herb
2019 BULLITT
..............thank you.............
