Track Alignment
Yellow350
Qatar
GT350 TrackPack
Hello,
Took the car to the dealer to make the Camber/Caster/Toe Alignment,
They checked, informed me that it's impossible to modify the alignment!! I was telling them what about the alignment sheet in the manual! No justification was givin,
Is it true? There is no possibility to adjust at all? If Yes, what should i do?
Thanks
Ctease
GT350
You can change the alignment. Go to a performance garage. I know Qatar has a lot of GTR & Patrol tuners. I'm sure someone can help you get it aligned properly.
J_Maher_AMG
Newfoundland, Canada
Justin
2017 GT350R (HR057)
Hello,
Thanks
You need aftermarket camber plates to achieve the specified track alignment. Do a quick search, whole threads on this concerning the different options out there and what people have done on stock setup.
Zitrosounds
Madison, AL
Harold
My caster is just at the FP settings but camber definitely needed aftermarket. You will need camber bolts at the very minimum and if your caster needs much adjustment you will definitely need C/C plates which will allow you to adjust both. The rear is easily adjustable to FP spec as is the front toe.
