TR3160 oil drain bolt torque spec ?
TDC
Long Island
Clutch engaged means having the clutch in its standard position. Sounds like you're referring to having the clutch depressed while stopped, when th clutch is disengaged. Only real negative to this is that your throw out bearing (clutch release bearing) will wear faster.
That makes sense now :doh:
Thanks for setting me straight on this one. Had the logic of the terminology reversed.
montreal ponies
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Any particular recommendations in regards to whether the transmission/rear diff fluid should be changed early on as part of a "break in" per se? Got almost 5000kms on mine and wondering whether I should change them come springtime when i take it out of storage, or whether premature changes were only meant for cars that see a lot of track time?
Well i'm not taking any chances, i just changed both tranny and diff fluids with BG Synchroshift II for tranny and OE rear diff oil from Motorcraft.
I saw quite a bit of metal shavings so in the end i think it was a no brainer for peace of mind and $100. :thumbsup:
montreal ponies
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Isn't the shop manual like $80... I mean... common.
Can you provide part # of said shop manual for $80. , cuz my Ford dealership which i just got off the phone with, tells me they don't see it in their system.
Unless you meant getting a service manual from a different supplier which i'm not aware of.
In any case, if anyone with a Shelby GT350 has a service manual ( book, not CD), please let me know where you got it. Thx
Epiphany
Global
I like to disassemble things.
  • Like
Reactions: TDC
montreal ponies
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Epiphany
Global
The GT350 is in the Mustang CD and does not have its own service manual.
montreal ponies
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Ok fair enough, but what do i choose in the above drop down menu ?
Epiphany
Global
In my case, I have the 2016 service manual on CD. If that is what you are looking for then this is what you want.
  • Like
Reactions: TDC
J_Maher_AMG
Newfoundland, Canada
Justin
2017 GT350R (HR057)
Do you by chance have the part #'s for those fluids or links? Any reason you went with the Motorcraft brand rather than an aftermarket fluid?
montreal ponies
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Hey Justin, check out my pic for product brand.
I went with BG tranny fluid as it is a better fluid than the ATF that Ford uses n our manual trans missions. I heard and read stellar reviews and know of different hard core racers that use this stuff.
As far as the rear end is concerned, i sticked with the Ford stuff for no particular reason.
montreal ponies
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Thanks mon ami. :cheers:
J_Maher_AMG
Justin
2017 GT350R (HR057)
Thanks man, just curious if the BG fluid states on the bottle that it meets Ford's "specs" or whatever standard they abide by? Wondering if there were ever an issue, could they possibly deny a claim based on oil being used that does not meet their internal specifications.
Sprintamx
Mid-Atlantic
2016 Shelby GT350
The manual recommends changing the diff fluid after 2 hours of track use, IIRMC. Whether that translates into time or miles for street-only driving, I won't speculate. But, when I changed my fluid after a few track events and approximately 3500 miles, it was quite discolored and the magnetic plug had accumulated quite a bit of "debris."
I went with a Motorcraft 75/140 formulation for a bit more heat capacity and durability, along with the Motorcraft friction modifier.
montreal ponies
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
There's a vendor on this site that sells BG fluid for the US, but i got mine at a GM dealership since it is what they use in all manual transmissions including Camero's and Crevette's.;)
tom185
NC
Tom
2017 GT350
It's a shame they don't support Windows 3.0 or NT 3.51. Helm better step up their game.
