GT350 oil pan torque specs
sigintel
Ray
2018 GT
Anyone have specs?
Stock GT w metal pan in 89 inlb + 45 degrees
anyone know gt350 nylon oil pan torque spec?
Hella thanks
Answer from Motorcraft
NOTE: If the oil pan is not installed and the fasteners tightened within 5 minutes, the sealant must be removed and the sealing area cleaned. Failure to follow this procedure can cause future oil leakage. If this timing cannot be met, tighten fasteners 6, 7, 13 and 15 to 8 Nm (71 lb-in) within 5 minutes of applying the sealer and final torque all of the fasteners within 1 hour of applying the sealer.
NOTE: Fastener locations 13, 14, 15 and 16 are stud bolts.
Position the oil pan onto the engine and apply pressure to the outside of the oil pan at the pickup tube until the pickup tube is fully engaged into the oil pump seal.
Install the fasteners.
Torque:
Stage 1: 89 lb.in (10 Nm)
Stage 2: 45°
