TR3160 oil drain bolt torque spec ?
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Anyone knows the exact torque value ? Thx
Epiphany
Global
I like to disassemble things.
WHOOP...on edit, I see you are asking about the TR3160 transmission and not the engine oil pan. Hang on, I'll look it up...
Epiphany
Global
The fill plug, on the side of the transmission, uses the same torque figure as the drain plug. Pay attention to the note regarding cooler equipped TR3160's.
montreal ponies
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
You're the man, thanks a lot bro. Oh BTW, where do you access those charts or whatever they're called.
Thx
TDC
Long Island
2 minutes with clutch engaged. Wow. Now I am not as concerned about the
2 - 5seconds max I allow for at a stop light.
Epiphany
Global
mattlqx
Driver
Mesa, AZ
Epiphany
Global
J_Maher_AMG
Newfoundland, Canada
Justin
2017 GT350R (HR057)
Clutch engaged means having the clutch in its standard position. Sounds like you're referring to having the clutch depressed while stopped, when th clutch is disengaged. Only real negative to this is that your throw out bearing (clutch release bearing) will wear faster.
J_Maher_AMG
Justin
2017 GT350R (HR057)
Any particular recommendations in regards to whether the transmission/rear diff fluid should be changed early on as part of a "break in" per se? Got almost 5000kms on mine and wondering whether I should change them come springtime when i take it out of storage, or whether premature changes were only meant for cars that see a lot of track time?
radamjr
2020 Shelby GT350
May sound like a dumb question, do you fill while it's running like you do with most automatic transmissions? or after 2 minutes(idle) , just turn off and top off ? Thanks in advanced!
Zombo
befejezett
2016 GT350 Track Pack - Race Red, Blk Roof - G5405
I suspect you fill it, close it up, run it for 2 minutes, shut it down, open it up and top it off. The running part makes sure all the lines and the cooler get filled.
