Timing vs knock for E85/boost
FastCarFanBoy
2013 GB GT
what is ballpark timing on a E85/10psi setup at 0 knock? I'm seeing 18@0 and up to 21.5@-3 ... does that seem right or a little conservative?
MyLilPony
Naw It's Stock
Prosper, TX
Kris
2015 Black GT, 18 JLUR, 15 JK
at 13# and 7700rpm i am at 21* and -3 knock...
beefcake
Bethel
2018 Ford Mustang
that will depend on your tuner as far as what they have it set at usually 20-21ish
BadGTR
Belen, NM
15 GT Auto, 1400HP GTR
Factor in actual ethanol content too. Everyone calls for e85, but allot of pumps never hit e85. E70ish is the norm and will have less timing threshold vs knock then actual e85.
MyLilPony
Naw It's Stock
Prosper, TX
Kris
This ^
I always test before I fill. I have one station that always tests 85% but it takes 2 gallons of gas to get there and back. The one next to my house tests at 80%.
FastCarFanBoy
FastCarFanBoy
2013 GB GT
so 21 all in is about right, thx for the replies.
Burkey
Australia
Can someone please explain to me why so little extra advance from the ethanol?
As in, if I’m seeing 19 degrees @ 12psi on ~92 octane, 21 @ 10psi appears to make e85 almost pointless other than the safety margin it provides.
What am I missing here?
BadGTR
Belen, NM
19 degrees on Super at 12psi is rather aggressive. And with true e85, I would think 24 degrees on 12#s would be within safe margins. On my other twin turbo car, I run 32#s of boost with 24 degrees timing on e85. Although it is only 9.5 compression.
kcc0521
Falls Church VA
Bo
2015 Black GT PP
The negative number is usually it adding timing. Your base table must be like 15 and it is adding 3 degrees. I am on a Paxton with 3.48 pulley and I see 21-23. You should be 21 bare minimum.
JennyStang
NY
2015 GT
I got 17.5 on 93 until I hit about 5.5k rpm then it jumps to 19 at 6k then 20 at 6.5k and maxes at 21 at 7k till 8k redline with zero knock
I’d be pissed to only see 21 on e85. You sure it don’t go higher than 21 closer to redline?
FastCarFanBoy
FastCarFanBoy
2013 GB GT
I would upload a log if I could figure out how, but I don't see over 20deg until 6700 in 3rd gear.
I know it hits the limiter on the 1-2 and closes throttle...that has been addressed in the last revision so disregard that.
JennyStang
NY
2015 GT
That looks like a log with max timing for 93 and not e85
markmurfie
Hawaii
Mark
2015 Ford Mustang GT
You are running like 7-8% rich, I'd test your E85 make sure you are not getting much less than what it was set for. If your tuner is thinking its E85 and you are actually getting e70 or less, this can raise your load, artificially, putting you at a lower borderline base value. Knock sensors will look happy and add in all the timing, but you will still be short cause it starts at a lower value. at 10 psi You should see like 1.6-1.7 load and possibly get to 22-24*, but with the timing in there from the start, starting at 19*, not be capped at 21 and have it adding in really slow like you are running 15-16PSI aka 1.9-2.0 load.
Tommy V
Brookly park Md
Tommy
I am.at 14 to 15 psi,and see 22 degrees of timing.Boost may be down.a little more now that i switched from cat deletes to long tubes.
