Throttle actulator ctrl sys stuck
samra
uae
mustang 2015 v6
Hello
I have a mustang 2015 v6
I recently had my idle shudder and sometimes car doesn't start after fulling fuel .
So i changed vapor carniester valve and car was working perfectly after that .
2 days later my car rpm rises and service sign shows
When checked the obd code P2111
Throttle actuator ctrl sys-stuck open and simetimes throttle actualtor ctryl sys stuck close.
If i restart the car it will work for sometime and then it happens again.
What could be the problem ?
Rod Schneider
Ball Ground, GA
Rod
2016 Mustang EcoBoost
Sounds like your throttle plate is sticking. It might need to be cleaned to remove oily build up that can occur, causing the plate to stick.
samra
uae
mustang 2015 v6
I have noticed it now happenig after i out reverse then drivr , 1 minuite after drive the throttle stuck
samra
uae
mustang 2015 v6
now it got worsten , after 4 restarts it starts working and then after putting reverse then drive , it gets stuck again
As suggested above - clean the throttle body blade. There's specific throttle body cleaner for EFI engines available at most parts stores or from online vendors.
Other than trying that, a service appointment is the only other option.
mustang6t9
Staten Island, NY
1969 Mustang Fastback, 2015 Mustang V6 coupe
Thanks all
I had the same code and problem with my 2015 V6. Replaced the throttle body with a new Ford unit. Easy job, maybe 20 minutes. You can order on line at places like Tasca Ford at a discount. I think the new throttle body and gasket was about $65 dollars. Car runs great.
