Think these will fit?
Evilcactuar
Connecticut
Jaime
2015 F250, 2016 Mustang, 1966 Mustang, 1973 Vega
I have a mach 1 handling pack car, I want a second set of wheels and tires for fall / early spring so I can drive the car a little more (in Connecticut, its dipping below where the tires are happy right now in the evenings and mornings). I ordered 4 closeout cooper zeon RS3-0G1 in 305/30R19, and was thinking I could get the American Racing Mach five wheel, they're available in 19x11 with both a 25mm offset and a 50mm offset. Will the 25mm offset fit the front with a 305?
DRAGOON
Wisconsin
Mark
21 Mach1 HP VB
For the same cost you could get the mach1 hp wheel with tpms from 1 of the site’s sponsors:
https://www.levittownfordparts.com/sku/m-1007k-mach1h.html
SheepDog
Colorado
Dax
Yes
Evilcactuar
Connecticut
Jaime
I was considering grabbing those, and i'm not opposed, theyre a great looking wheel. I was hoping to get some lighter wheels. These are like 24lbs and I believe the Ford performance wheels are closer to 35. I looked at some of the mrr and sve wheels (again, because to save weight) but didn't find anything that would fit a 305 tire.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
The 19x11 +50 offset for the rear will fit perfect, the front 19x11 +25 will have a slight more of a poke than the factory 19x10.5 +24. A slight alignment change for the front will help with the poke.
Evilcactuar
Connecticut
Jaime
Yes, I decided on P51's in 19x11 and 24 and 50 offsets, almost these exact sizes, ran it through a calculator and came up with an additional 6mm in the front of poke. I figured i'll adjust the camber a touch from 1 to 1.8 and I should be in business. (I also ordered some rokblokz)
shogun32
Northern VA
Yup. But you might want to downsize to 9.5 or 10 for massively more selection and more ground pressure.
The mrr m600 seems to available again. I've got a new 10/11 combo if interested ($700). Or you can find 10 square esp on eBay for about thousand.
Evilcactuar
Connecticut
Jaime
I ordered everything last week so its a moot point, but I wanted to stay with the largest rubber I could get. I understand thats pretty limiting on tire choices.
