Phantom2015
So I'm going to install the 170 thermostat this weekend. For the people that have done it , will I lose a lot of coolant when doing it or just a little thanks ?
Any tips?
Any tips?
thanks and do you think it was a bad thermostat? probably that one in a million. only reason I'm switching is because of the flex fuel tune and it bugs me the fan turns on so fast now.This video shows how to drain the coolant reservoir. When I put the 170 in my car I went to the trouble of jacking up the car and removing the under tray and completely draining the radiator. Save yourself some time. Drain the coolant tank/line and change out the thermostat. You will have to remove the CAI to get to it. If you get a plastic cup to catch the remainder of the coolant removing the thermostat spillage will be a minimum. Have a bucket in arms reach to dump the cup because the other hand will hold the hose up to keep coolant from draining out until emptied using the cup. My 170 failed and caused my car to flash a code saying the car wasn't warming to proper running temp. Head temp was 158 deg/f so I switched back to factory.
It's not a pain at all. 15 min swap.Really worth doing this mod? I've done it on my 97 GT easy, but these cars sounds like a pain lol
So I got the Lund flex fuel tune and he has the fans turning on earlier for better cooling due to the tune. So the fans are almost on all the time and it bugs me to hear it haha. So since the 170 opens up at a lower temp the fans wont kick in all the time. It will be like it was when I was stock and yes way worth it to have a E85 tune. Car pulls so hard compared to stock.Really worth doing this mod? I've done it on my 97 GT easy, but these cars sounds like a pain lol
Awesome, I didn't know what mods you had, you should add them to your sig ;)So I got the Lund flex fuel tune and he has the fans turning on earlier for better cooling due to the tune. So the fans are almost on all the time and it bugs me to hear it haha. So since the 170 opens up at a lower temp the fans wont kick in all the time. It will be like it was when I was stock and yes way worth it to have a E85 tune. Car pulls so hard compared to stock.
I pretty much did the same thing too. Just had a deep pan under the car and hosed the front of the engine and pan out. In terms of fluid loss, I added almost 1 jug of Motorcraft 50/50 mix when it was all said and done. You will need a tune to adjust the fans. My fans were on almost constantly, very annoying! Once I had the tune, fan issue gone. It rarely kicks on, but we are not in the summer months yet. Coolant temp has been sticking at the 170 mark when I am running her hard, no issues!You are going to spill and make a mess on the engine no matter what. I didn't drain anything. Just took off the thermostat housing, swapped it, refilled coolant, and washed off the front of the engine with a hose.
I doubt your car stays at 170 coolant temp when your running a 170 stat let alone running it hard.I pretty much did the same thing too. Just had a deep pan under the car and hosed the front of the engine and pan out. In terms of fluid loss, I added almost 1 jug of Motorcraft 50/50 mix when it was all said and done. You will need a tune to adjust the fans. My fans were on almost constantly, very annoying! Once I had the tune, fan issue gone. It rarely kicks on, but we are not in the summer months yet. Coolant temp has been sticking at the 170 mark when I am running her hard, no issues!
