The Small Questions Thread
new302
Jon
16 PP GT
[MENTION=27867]ChristianDev[/MENTION] window sticker will indicate if it has an optional ratio. standard for your car was 331. optional was 355. You can usually google to decode the axle code on the drivers door jam to determine the ratio
JKL1031
JKL1031
Jxn, Ms
15 GT PP Premium
That happened in my prior 2016 - nothing like that in the 2018, so I’m assuming something is different with the materials or how the dash components are mater together behind the dash.
There should be foam strips everywhere the dash touches the body. Sounds like rocks r hitting the windshield when the HVAC heat gets warm.
Grimmer
Utah
2016 GT/CS M6
Small questions about the HVAC (2016 GT M6):
First question: Does anyone notice when it is quiet (stereo off) in the car with the HVAC on that their fan rpm hunts up and down? It is like the fan can't decide if it should be on the lowest setting or the second lowest setting so it randomly switches back and forth. (Baseline on the lowest setting, random short-lived switches to the second lowest.)
Second question: When I get in the car on a cold morning and start driving, once the engine heats up the heater is very zealous about heating the cabin and dramatically overshoots the set temperature. For example, it is 30 degrees F outside in the morning. My auto-temp is set at 70 degrees F. Once the engine heats up enough the car is blowing full hot air WAY past the 70 mark to the point of being uncomfortable. However, if I lower the temp set point 2 degrees, it will back off and eventually control just fine. It does this for most of the temp set points I've tried (it happens even when set to 68 and 66 - no reason to blast heat to achieve 60). After the engine has warmed up, parking the car and restarting it the temp control works as I would expect. Is this a deliberate programming error in an attempt to compensate for the initial chill in the cabin on cold starts? Or is there something screwed up with my HVAC controller?
Grimmer
Utah
2016 GT/CS M6
@ChristianDev window sticker will indicate if it has an optional ratio. standard for your car was 331. optional was 355. You can usually google to decode the axle code on the drivers door jam to determine the ratio
The other choice (3.73) is locked hand-in-hand with the performance pack. So you can rule that one in or out fairly easily.
The door jam axle code on my '16 with 3.55 is "DD". I think the 3.31 is "GG" but I can't confirm.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
There is a sticker on the back bell housing of the diff itself. It will say the ratio.
GTP
Deutsche Pony
Indy
Philip
This is my first auto climate car, and mine works perfectly. I set it and forget it. Really enjoyable.
Others have claimed they aren't so impressed. I'd have yours checked out.
Grimmer
Utah
2016 GT/CS M6
Is it possible for the "H" pattern in the shifter to be slightly out of alignment with the actual gears in the transmission? All too often a shift from 2 to 3 seems to get stuck exactly between 1 and 3 and doesn't want to go left or right. I wondered if the pattern plate (assuming such a thing exists) on the shifter is just a hair off and the slot for 3rd doesn't properly align with the internal gear position. If so, an adjustment might also alleviate that slight "crunch" that is almost always present when shifting into 3rd.
JKL1031
JKL1031
Jxn, Ms
15 GT PP Premium
I guess it's normal for the brakes to squeal with PP brembos?
Loki-GT
IL
2018 Mustang GT Premium A10-3.55-400a
Your wife told you not to buy it but you did anyway? :brokenheart::shrug:
:thumbsup: Exactly, was in the dog house for, wait, still in the dog house. :headbonk:
druby
Idaho
David
2015 GT PP Premium, Tripple Yellow
I've researched this one a lot. Many folks say yes, that's what you get with Brembo's. I think I've come to the conclusion that you have to drive a bit more aggressive than I'm used to in my old car. Rather than gliding to stops all the time, these brakes light it a bit rough.
druby
Idaho
David
Do any of the aftermarket clutches have the clutch pedal engagement point closer to the floor? I can't stand how high up the stock clutch grabs, it's tough to shift smoothly.
I think I've seen some threads about this. I have the same car and have also found it to be tricky to shift. I haven't driven a stick in about 10 years though. I think that a lot of people remove some sort of spring. I haven't tried it yet, as I'm just trying to get used to it/figure it out myself. Try searching the general forums and I'll bet you find a bunch.
Rc18
Georgia
Ben
6mt-rc-18eb
Remove the clutch assist spring to solve this.
Removing your stock clutch assist spring solves the weird takeup point issue&vague clutch feel.
To remove simply depress the clutch pedal fully, use a pair of vise grip or other locking pliers on the spring itself. The perch is on the upper right side of the clutch pedal. After clamping down on the spring slide whole assembly to the right and it will fall out/come off easily. I've been driving like this since I got it and it really is a world of difference:cheers:
JKL1031
JKL1031
Jxn, Ms
15 GT PP Premium
I think there's a certain pad that dowsnt squeal.
Blue Moon
Maine, or eastern Canada
Pete
17 Ecoboost Perform Pack Std
For $20 you can get a different clutch spring from Steeda, which gives the clutch a better feel than the stock spring, but is not so extreme a change as simply removing the spring.
oneheadlite
WNC
2021 Mustang GT PP1 2008 Saturn Sky Redline
Quiet?? No stereo playing??
That will never happen in my car.................:headbang:
