Gloucesternige
So, as most of you will know Bristol Street Gloucester fitted a new door to my GT and in the process painted the whole side of the car. Great!!
In doing so they removed the quarterlight and refitted it badly after mullering it getting it out. Now I have carried out the necessary repairs and have a new window in the way.
Moving on to the door I have noticed the door glass is not fitted correctly and is way off in its shut dimensions. It should be 10mm from the steel flange and 10mm down from the door opening at the rear and 9mm down at the front. This comes from the FORD manual, so you’d think that having the work done at a FORD garage the work would be good? Well, all the above dimensions are around 20to 22mm on my car!!
So, I’ve had to remove the door card to get in there and adjust it all. Guess what I found?? Damaged trim, missing clips, torn rubber trim and NO wax!!
Why do Ford make such a fuss of having Ford insurance so you only get genuine Ford parts, well, the parts they can be bothered to fit that is!!
I’m so pissed off right now!!
