The 3.55 Axle OPtion
DJGold
Quebec, Canada
Ford Mustang 2015 V6 Manual (3.55 diff)
Very important to have 3.55 gears if you plan on putting on bigger diameter wheels (20's) (like I did).
Bay1Stang
Magnetic '15 V6 051a
Went for a joyride today since the roads are FINALLY clearing up. Soooo much fun. I've never had so much power available to me before so I'm always feeling the acceleration. Any time I'm passing I don't even get that high in the rev range and I'm already speeding. Best part is the engine noise is so satisfying I never even think about putting the stereo on.
Btw, can you explain to a noob like me why the ratio is important relative to wheel size?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Generally larger wheels are heavier and have more rotational inertia. Rotating mass affects performance more than the equivalent static weight by a magnitude of a few (2-4) times.
DJGold
Quebec, Canada
For some unknown reason, increasing wheel diameter will actually lower final drive ratio numbers. I'm guessing my 3.55 actually acts like a 3.31. So 3.15 would feel like ???
BmacIL
Enginerd
Naperville, IL
That would only happen if you went to a larger tire diameter.
DJGold
Quebec, Canada
I know but I still agree with this ^^^^^
Jamo
Jamo
Twin Lakes, WI
1997 Cobra Coupe
Something occured to me while this was keeping me awake last night. In order to get the $395, 3.55 option on the V6, you have to buy the $995, 051A package, which is mostly the wheels (okay, the power seat and the fog lights, too. But mostly the wheels.
But the wheels aren't that great. A lot of people could spend $1400 on 19" better wheels and be very happy. Maybe yu expect to. I did.
If that's the case, then you're paying $1,400 for the axle that doesn't cost Ford anything extra at all, (because they're just keeping the 3.13). I'm not sure it's a good idea after all.
How about just a base V6 MSRP $24K? (I searched. There's a Guard one somewhere around me, if anyone likes Guard.)
Bay1Stang
The base is nice because of the price. The 3.55 gears will be for sale so you can get them installed after the fact. The 051a package also comes with better stock tires I'm pretty sure, but if you're buying base and getting a new set that doesn't matter.
Bay1Stang
Jamo
Jamo
Twin Lakes, WI
1997 Cobra Coupe
BmacIL
Enginerd
Naperville, IL
I think there's more to it than that. And more cost. And more danger if it isn't done exactly right.
Only certain shops are certified to do it, AFAIK, and from what I remember, installs were typically in the $400 range. And Bay1Stang is right that the tires on the 051A wheels are definitely better, genuinely good high-performance all-seasons.
If you don't like your 051A wheels, I'll take them off your hands for my winter set :cool:
DJGold
Quebec, Canada
Since when? I have a base V6 (without 051A) and I have the 3.55 diff. option...
Jamo
Jamo
Twin Lakes, WI
1997 Cobra Coupe
Maybe in Canada. Not around here. How do you like it? Any ragrats about not getting an EgoBoost?
DJGold
Quebec, Canada
I'm very happy with it. I never tried the ecoboost but I know I would miss the sound of the V6. Exhaust note counts for a lot in your mind when you're driving. It makes you feel powerful. I did try a GT recently and if I lived in the states, I would have gotten that (it's nearly $13000 more here between V6 and V8). I wanted a DD so a GT might have been overkill.
dgc333
MA
15 Mustang Ecoboost Premium
Wheel diameter has no impact on final drive ratio. It is the outside diameter of the tire that will impact your final drive ratio.
For instance the stock 235/50-18 tires are 27.3" in diameter. The optional 265/30-20 tires are also 27.3"in diameter. Ford sizes tires to go with the optional wheel sizes specifically not to impact the speedo and final drive.
The 265/75-15 tires on my pickup are 31" in diameter. Even with 3.91 gears the engine is loafing at 1700 rpm on the hiway.
