Tapping noise in engine or transmission?
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
Posted this in the Mach 1 section without much success so trying here.
New Mach 1 with the Tremec manual and 200 miles on it. Sitting at idle with the transmission in neutral, you can hear a faint metal-on-metal tapping or knocking noise and can lightly feel it if you put your hand on the shift knob. Very regular, happens all the time, but the intensity seems to change a little. Sounds kind of like someone is quickly tapping on something solid with a small hammer. Pushing in the clutch has zero effect on the sound. I really can't tell if it's in the transmission or on the engine side of the transmission, but it does not sound like a serpentine belt area tick or a low octane detonation knock. Checked the engine oil level but it's normal. Any ideas or thoughts would be appreciated.
vintage1
Canada
2017 Mustang GT PP
Hi, I would check your drive shaft. Bar code lable maybe spinning off and hitting body. I had a similar issue a few years back and this was it! Good luck.
Milton
Toronto Canada
Sqeekywheel
2020 Gt premium PP1
Any videos
Any videos?
Mikepol2
Mikepol2
Pittsburgh, PA
Will try to get one but hard to get it audible over the exhaust even in quiet mode with my crappy camera.
Not sure if the noise you are hearing is coming from console area. Check to make sure emergency brake cable isn't loose. It is located under driver side floor pan. If the cable is loose it allows slack in the assembly and it taps or rubs against bottom of floor pan or exhaust. You can only see it if the car is up on jack stands or ramps because it's tucked under trans tunnel.
There's a thread on here in DIY section with how to adjust.
