Mikepol2
- Jul 17, 2018
- Pittsburgh, PA
- Mike
- 2021 Mach 1, 2019 Ram 1500
Posted this in the Mach 1 section without much success so trying here.
New Mach 1 with the Tremec manual and 200 miles on it. Sitting at idle with the transmission in neutral, you can hear a faint metal-on-metal tapping or knocking noise and can lightly feel it if you put your hand on the shift knob. Very regular, happens all the time, but the intensity seems to change a little. Sounds kind of like someone is quickly tapping on something solid with a small hammer. Pushing in the clutch has zero effect on the sound. I really can't tell if it's in the transmission or on the engine side of the transmission, but it does not sound like a serpentine belt area tick or a low octane detonation knock. Checked the engine oil level but it's normal. Any ideas or thoughts would be appreciated.
