Sync wire for front speakers?
Remy_reign
Grand rapids Mi
REMY
2015 Oxford White GT Base
Looking to run new wires for my speakers, and i have been hearing if you replace the front speakers you lose sync sounds. Has anyone found a way to get passed this?
Plans
aftermarket speakers
aftermarket amplifier
and lcq 1
smdandb2
ManBearPig
Uranus
2017 Toyota Corolla SE
Just don't tap off the rear speakers for the amp signal and you will be fine.
There is a sticky in the top of this section that has everything you need to know.
Zemedici
Kennesaw, GA
Josh
2015 GT/PP
what wattage of speakers are you wanting to run to justify needing to add an aftermarket amp?
Remy_reign
Remy_reign
Grand rapids Mi
REMY
Seeing how everyone that has replaced their speakers state it sounds 100x's better but still no bass, I rather run my speaker wires to my lcq 1 to an aftermarket amp then to the doors and rear. I like the bass in my 14 premium and still wanted a little more. This base 15 is a total let down when it comes to sound.
Are you saying I wouldn't need to run new wires? Just cut in for the lcq before and after the stock amp?
Zemedici
Kennesaw, GA
Josh
2015 GT/PP
if there's no major increase in wattage, I don't see a reason to replace the wiring. I've put aftermarket speakers in a TON of cars, and never once had to upgrade wiring. Just seems like a bunch of extra work, imo.
smdandb2
ManBearPig
Uranus
Good luck running new wires to the doors.
That was my plan, and I had to abort it mid install. The harness going into the doors has a bulkhead connector on the car side and it did not exactly seem easy to pass new wires thru that.
