SYNC 3 plus Apple CarPlay update
kratty
DC area
'56 Victoria, Tahoe, '16 GT350
If you're having trouble with the USB approach, it's probably worth the minimal investment in a new USB stick. As others have said, file size is 2gb or less. The file written back onto the USB is a very small XML file, so that's not the issue.
Tank
9/11 - Never Forget
Above the Notches
G0853
So I used a 32 GB USB, exFAT formatted that seem to go through. The "Version 2.2" notification took an extra 5 minutes or so to show on my screen. The update took about 20-25 minutes and my GT350 did not turn itself off as others have reported.
Nav maps were updating for about 20 minutes more when I turned it off figuring they would update when I next took it out.
I did have an issue trying to upload the .xml file back to Ford. When I upload it, it adds a C:\fakepath\ then the file. I tried to drag the file to my desktop and the same address gets added...
Any thoughts?
Thanks in advance :cheers:
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
I just finished my update, but I had some problems. First I downloaded the zip file to my Mac and saved it to a 16GB thumb drive. I got error messages such as " Installation has run out of space or does not work with this version". I tried saving to my 512GB solid state drive and got the same results. I went back and used my Windows laptop to download the zip file and saved it to the 512GB solid state drive. Plugged the SS drive into the car, that finally worked great, the update took 24 minutes.
My drive is formatted for FAT32, no problems with that format.
Spacebird
Boulder County, Colorado
2016 GT350R
I just have missed something... you have to send a file to Ford??
Tank
9/11 - Never Forget
Above the Notches
G0853
I guess you don't have to but they want you to. It helps track your version for future updating.
The updating process puts a .xml file on your USB that your asked to upload on the Ford Sync site. I assume wifi takes care of itself.
If you haven't already, set up an account at the Ford Owner website, it'll walk you through it.
Good Luck SB:cheers:
lemers
Globetrotter
Carlisle, PA
2016 GT350
This morning a did a manufacture reset on the sync and then plugged in the USB.
I drove to work (about 30+ mins). Again, the screen has a message at the top saying that it is updating, but there is no status bar or changes being applied. When I got to work I pulled the USB and it said that the update would continue when I replaced the USB.
Not sure what I'm doing wrong.
Crashspeeder
2016 Shelby GT350 - Tech
Just a quick update from me. I had never installed a leaked version. Over the last few days this is what worked and what didn't:
  • 8GB USB2, FAT32: Failed
  • 32GB USB2, FAT32: Failed
  • 8GB USB3, exFAT: Success
  • WI-FI update: not available
Not enough testing on my end to conclude if the problem is USB2 vs USB3, FAT32 vs exFAT, USB stick quality/age. It would seem, however, that the difference in size (8GB vs 32GB) was not a factor since the update that succeeded was also on an 8GB stick. I made sure to try a different stick each time, so if you guys have multiple sticks try them all until one works. exFAT will work, and it seems Ford has updated their site to suggest exFAT over FAT32. Best of luck to all.
EDIT: It turns out that nav didn't update and I now have no nav on the car, only through Android Auto. I'll have to see how to get it to install only nav.
EDIT 2: Apparently you need to turn off the vehicle TWICE before everything is done updating. The first time you turn the car back on after updating the system does one last bit of updating, but if you take a look at your sync version you won't see anything for nav. The second time it boots up you'll see everything is back to normal.
kratty
DC area
Did you unzip and extract the files from the downloaded zip, or did you just move the whole downloaded zip file on your thumb drive?
GT_Dave
NE Illinois
They were extracted, in Windows 10 I think that process is automatic when they are transferred to the drive.
lemers
Globetrotter
Carlisle, PA
2016 GT350
So i finally got it to work!!!! Yeaaaa!!!!
I bought a new USB stick and used a different unzipping program
Helmet
Korea
Dude
2016 GT350 Track Pack
I think it might help people resolve their issues with the updates if those who updated successfully were to list the brand, capacity, usb version and file format.
Tank
9/11 - Never Forget
Above the Notches
G0853
If you can't upload .xml file after install...
I contacted Ford Sync via chat and they opened a case for me. They asked I send the .xml file to them and within a few hours, I got confirmation they will take care of it. I don't know if this would have cleared on it's own and they didn't tell me anything about what prevented me from uploading in the first place.
lemers
Globetrotter
Carlisle, PA
2016 GT350
I used a 32gb PNY 3.0 thumbdrive formatted with exFAT.
kratty
DC area
ducatismo
ducatismo
Ducatismo
DALLAS
2016 GT350
Congrats! It's super frustrating to attempt to install with no success but when it finally clicks it's all good. Funny how the smallest details, like using a different usb, make the difference. Trial and error I guess.
