Thank you, will check it out.First thing I would try is wiping the APIM clean and reinstalling everything:
https://cyanlabs.net/applications/syn3updater/
Follow their instructions to the letter. If you have any questions, ask here before proceeding. It's pretty easy, I did it to a 2016 after a 4 to 8 conversion. Works like champ.
Looks like the forscan codes spreadsheet has been deleted? Did it get moved somewhere else? Thank you.Also, don't forget this:
https://www.mustang6g.com/forums/threads/forscan-codes-s550-mustangs.98260/
| Soft Climate Buttons (On Touchscreen) | Disabled | APIM | 07D0-01-01 | xxxx | xxxx | x0xx |
| Soft Climate Buttons (Seat Cooling only) | Enabled | APIM | 07D0-01-01 | xxxx | xxxx | x1xx |
| Soft Climate Buttons (Seat Cooling & Heating) | Enabled | APIM | 07D0-01-01 | xxxx | xxxx | x2xx |
| Soft Climate Buttons (Seat Heating only) | Enabled | APIM | 07D0-01-01 | xxxx | xxxx | x3xx |
Thank you, checking these out.Here is a link to some of the spreadsheets. Make sure you look in the Forscan options for the module, as a lot of these toggles are menu options now.
https://www.mustang6g.com/forums/threads/forscan-codes-s550-mustangs.98260/page-21#post-3583036
Thank you, will check out today, appreciate it.Do you have these set properly based on your car info? If you have none of these options, then check to see if it is disabled... Zero
Start here but also try and look through the original thread below...
Soft Climate Buttons (On Touchscreen) Disabled APIM 07D0-01-01 xxxx xxxx x0xx Soft Climate Buttons (Seat Cooling only) Enabled APIM 07D0-01-01 xxxx xxxx x1xx Soft Climate Buttons (Seat Cooling & Heating) Enabled APIM 07D0-01-01 xxxx xxxx x2xx Soft Climate Buttons (Seat Heating only) Enabled APIM 07D0-01-01 xxxx xxxx x3xx
SYNC 3 swap, It's all in here | 2015+ S550 Mustang Forum (GT, EcoBoost, GT350, GT500, Bullitt, Mach 1) - Mustang6G.com
and
Modifying As-Built Data Guide | 2015+ S550 Mustang Forum (GT, EcoBoost, GT350, GT500, Bullitt, Mach 1) - Mustang6G.com
Post #11 has a short cut to Forscan changes spreadsheet which may help also...
