SW header install question
NewTekBuzz
Flint, MI
Tim
2019 velocity blue GT 6M - 2015 Black GT 6M (sold)
There was more room after install but looks like the engine settled and moved closer to the AC line bolt. Is this too close? What do I need to look for?
RubyRedBoost
Traded EB old name New GT
Fort Worth
Josh
2015 Guard GT with PP
It is way too close. It will make contact with the bracket. This can damage the header. As well as cause false knock causing the car to pull timing.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
That's about 3/16" to a 1/4". Where would the false knock show On a nGauge?I think I'll take a file to the nut or try and shimmy the engine over
RubyRedBoost
Fort Worth
Josh
You would see positive numbers on the KnockR gauge. I had to remove the whole bolt and bracket as well as shift the motor. There is a thread on this that I started with a few fixes.
RubyRedBoost
Fort Worth
Josh
Problem is these tag the bracket and the bolt under load. These headers are the same as the 11-14s. Not redesigned just different mid pipes. So they do have a slight fitment issue.
NewTekBuzz
NewTekBuzz
Flint, MI
Tim
Yeah I remember the thread and removed the end of the bolt. My KnockR is never been positive, it goes negative under throttle but never positive.
Thanks for the reply
RubyRedBoost
Fort Worth
Josh
Then you should be fine.
CeleronXXX
albany
2015 TY GT PP
I just pulled my bolt and bolt mount out completely the ac line seemed fine without it. What I don't understand is if you look directly down on mine just like in your picture the primary under the one you can see in your pic seem to kick out towards the frame rail and I only have about 1/4inch of clearance. I was touching at first but I put a ratchet strap on it and jacked it towards the passenger side from underneath. No false knock but I still think it's to close. I'll be damned if I'm taking them back out though
RubyRedBoost
Fort Worth
Josh
It's not an issue once corrected.
rozay
South Florida, Broward
2015 PQ 5.0 MT
Really? So I can buy a 11-14 header but use a 15-16 midpipe?
Sent from my SM-G930T using Tapatalk
RubyRedBoost
Fort Worth
Josh
Yes. I was told by their GM they only checked fitment. It is the same unit.
RubyRedBoost
Fort Worth
Josh
A little proof for reassurance.
RubyRedBoost
Fort Worth
Josh
This is the start sorry.
rozay
2015 PQ 5.0 MT
Nice thanks
Doctor Fishtail
Mexico
Mustang GT
Is this only a SW Header issue or is this a problem with all headers?
