NLGT
- May 7, 2017
- Eastern Newfoundland, Canada
- 2015 Mustang GT PP
Hey guys,
First post here. Great spot with a lot of great info. I've been lurking around the past few nights, doing a lot of reading on all of the different suspension setups. First off, what I have and what I'm dealing with:
2015 GT with Performance Pack. Steeda Diff bushings installed, Steeda IRS Subframe Alignment kit & Subframe Bushing support to be installed shortly.
I find the car has the "Bouncy" feel many people mention, and am not a big fan of the nose pick up and dive when onto the gas and brake hard. I'd ideally like an all around further setup to get rid of that floating feeling and the nose movement. A harsher ride is too be expected, but I don't want it riding like a tank either - the roads here in Newfoundland are FAR from great - lots of potholes, uneven surface, ect. I'd also like to squash a bit of that wheel gap too, it rides really high.
Car is not daily'd, only used from May to September on good days and then stored. I like to push it in the twists, and would like to do a few autocross events this season. Not every weekend or anything, but hit up a few.
The setup to beat appears to be BMR SP080's or Steeda Ultralite Lineras running with FRPP or Steeda Shocks/Struts - any thoughts on this?
My main concerns:
- Can the car take the drop with springs and still be able to be aligned back to reasonable PP specs? Camber plates a must, maybe, or not needed unless dropping way low?
- Are shock/strut changes required to remove the bounce (it seems the answer on this is yes, and I'm leaning toward locally available Steeda Non-Adjustable. The FRPP set is another 500 by the time it gets up here)
- I see a lot of mention of various additional parts (RLCA Bearings, ect) are these needed to avoid other issues (Noises, clunks, ect)
I figured I'd make a new post just to see if anyone out there has a setup that similar to what I'm looking for, and your thoughts on it? I'd hate to order parts, have them installed, and end up with a similar or worse performing setup as what I have now, or have a machine that sounds like it's going to come to parts with squeaks and knocks.
Thanks in advance, and happy to be a member here on the forum!
My main concerns:
